40,000 miles
Apex Clipper
Originally Posted by MyK24a
Hi guys I'm reaching my 40,000miles mark for the car. What are the things that should be change during this servicing?
Just kidding... or am I...
Just do normal maintenance. Maybe check your 'plugs and gaps. Other than that, tune-ups shouldn't be necessary...
I wouldn't worry about 40k, just changed the oil and air filter.
And to correct one thing, TSX comes with super thin tip irridium spark plugs, don't gap them because you will damage the firing tip.....
Because Of You
I have 65k in my car. I haven't done nothing except changing oil. Even the tires still look good. But I have noticed one thing. I am begining to hear wind noise from the door. So... I guess it is a good idea to lube the plastic shield more often...
Do you have the stock original tires after 65k?
HOWARD911S
eh. you mean you havent changed tranny oil. no new air filter.. no new brake fluid...? no new brake either?
Because Of You
Originally Posted by 04EuroAccordTsx
I'm approaching 40K miles and want to know what they do and the typical cost for the 40K service.
Its a typical oil change and tire rotation. Around $40 I would guess.
John Starks - The Dunk
When would you replace the ATF? I haven't done that yet and I'm near 70k. Only thing the dealer has done for me at each 10k mile interval is the oil change and rotate the tires. Brake pads and tires were replaced at 50k
didn't see that listed anywhere at:
FAQ:Maintenance Schedule
Originally Posted by jlukja
There are several threads on tranny fluid replacement. I thought it was at 60K mi. but that doesn't seem to be the case when looking at the maintenance schedules. I was planning to do mine at around 30K mi. I think if you're at 70K mi. then you should probably think about doing it soon. From what I gather its rather straightforward, you just drain and fill.
mada51589
05-03-2022 08:54 PM
Legend2TL
11-20-2015 07:31 PM
mugen_kid
11-13-2015 10:38 PM
