3500 RPM at 80 mph???!!!
I agree -- I don't know what the heck Acura/Honda was thinking when the geared 6th that way. Totally stupid IMHO. The 6MT should be able to get 33-34 on the highway if Honda would wake up and make 6th the cruusing gear it should have been all along.
Wow.. I'm glad you folks were not the ones making the decisions at Honda headquarters for tranny gearing, because I sure enjoy the short gearing of my 6MT, especially for cruising, since it helps the cruise control maintain razor sharp speed accuracy.
sauceman, who achieves as much as 38.5mpg with a 6MT, and who celebrated yesterday 100,000km.
Of course this doesnt translate as well to north american roads and driving.
I like the ratio of 6th gear. 2nd needs to be shorter or first needs to be taller but other than that the tranny is great.
Congrats on 100 megameters! You're one tenth the way to a gigameter!
Originally Posted by Un-Kut
WTF, is it just me or isn't it usually 3000 rpm at 80 mph??? The TSX gearing must be EXTERMELY short
It's right on target for a 4-banger in top gear, and not too out of line even compared to other cars. A BMW 325i turns about 3400 RPM at 80 RPM as does the Jetta 1.8T (although the GLI has different tires and turns about 3100).
Lot's of folks here think they'll get better mileage with a taller gear, but the picture is muddy. My 1.8T turns over 3500 RPM at 80 mph but gets better mileage than the GLI (same motor) which turns almost 10% fewer revs. Go figure.
Originally Posted by xizor
I get 33MPG highway w/ 6MT, just takes a disciplined foot. I like the gearing how it is, the only thing I would change is the 1st->2nd shift.
What is the disciplined foot of which you speak?
Maybe my problem is that i can't stay away from that fantastic WOT
That's an enimga at best. I've seen you tout this a few times, but honestly I bet you didn't really achieve that. You probably just didn't get the tank completely full (because of and incline at the gas station or what-not) so when you divided your odometer milage by how much you put in your tank your MPG only appeared to be that good. I've seen bogus MPG values like that a few times with my Civic.
WRT the gearing issue, I also think that 6th should be geared taller, it should increase hwy mpg and probably reduce hwy noise/vibration as well. On the 1-2 issue, 1 should be taller, 2 is in line with the kind of ratio diff between 2-3, 3-4, 4-5. I think it's been made so short to give lots of squirt from a start but it actually makes it a bit harder to drive than it needs to be.
With 6th being so short, it makes 5 kinda useless, I almost never use it. When accelerating to hwy speeds I shift 4-6 instead.
If you want better proof, just drive up here and see it for yourself.
Sauceman, I'll read over your old posts sometime -- but for the record I never meant to claim you were intentially BSing.
Maybe you're MPG figures are correct. Maybe your TSX has the timing turned back more the most making your fuel economy better (but on the flip side your engine would be producing less power than most).
My MPG figures are definitely correct, because they are constant over 14 months and 100,000km of driving.
I drove cross country and got consistently 32-35 MPG and can substantiate that cruising with gentle lane passes will produce great mileage. This was done cruising at about 75 (wife with me... couldn't break into triple digits) for 4-5 hour stretches.
....Lot's of folks here think they'll get better mileage with a taller gear, but the picture is muddy. My 1.8T turns over 3500 RPM at 80 mph but gets better mileage than the GLI (same motor) which turns almost 10% fewer revs. Go figure.
Nothing is muddy! We all know the 5AT has a taller top gear, and it gets more MPG on the highway.
joflewbyu2
08-18-2019 10:38 PM
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
