3000 miles and 50% oil life?
Chris
My car is 3000 miles old and it says it has %50 oil life left. I thought it was wise to change the oil every 3000 miles....am I wrong? Is it better to stick to the 3000 mile mark or wait till it gets to %10 or somewhere inbetween?
Also, what oil do you guys recommend? Synthetic? Brands? Do you recommend taking it to your dealer or an outside shop like a Midas or Monroe? Dealer will probably be alot more.
Dont switch to synthetic until the 2nd oil change. For the 1st oil change you want to stick with the regular Honda stuff. The motor is still running in at that point and switching to synthetic that early would not be ideal.
You dont need to change the oil yet. the 2005 manual stated 5000 miles or 6/mo whichever came first if I recall. I would stick to this regardless of what the maintenence minder says.
The maintenance minder thing is reasonably reliable--I trust mine. It generally tells me to go in every 4000 to 5000 miles (depending on my driving habits). You are welcome to change the oil as frequently as you wish of course, but you may not be getting your money's worth from the oil if you stick to a rigid schedule like that. It sounds like you are pretty gentle on your oil
TSX: Boeing Dreamliner!
Change the oil at 5000 miles or so. We have a CRV - 07 and we've done 2000 kms and it says we have 90% life left - when its cold moisture builds into the oil and it needs to be changed faster. Don't use synthetic until the 3rd change - I've got it in for the first time in my 05 for the winter. I think the engine runs a little smoother at start up when its cold then before but when its hot, no difference. I'm going back to GTX on my next change.
Received 3,860 Likes
I used honda oil for the first year and now I use Valvoline SynPower Full Synthetic.
Originally Posted by aaronng
Wait til 10%. It doesn't mean that you have no more oil in your car. It's a measure of oil LIFE, not oil LEVEL.
The maintenance minder is there for a reason. Why not follow it and wait till it says 10% left. As has been said here, and on tons of other threads, you can change it more often if you like but you're not going to see a benefit of more frequent changes. I also agree with Brandon24pdx that you should wait until your 2nd oil change to switch to synthetic. BTW, I use Mobil1.
1000 miles and oils at 70%.. lol is that bad?
Question has been asked and answered. Since there are already existing threads on this topic I'm closing this thread. If you want to continue the discussion, do it in one of the following open threads:
Maintenance Minder:
https://acurazine.com/forums/showthread.php?t=34099
Synthetic:
https://acurazine.com/forums/showthread.php?t=32560
Switching back to regular from synthetic:
https://acurazine.com/forums/showthread.php?t=3800
Maintenance Minder:
Synthetic:
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
