2Gen TSX Key on 1Gen TSX
Old 10-03-2008 | 04:46 PM
V-TSX's Avatar
Post 2Gen TSX Key on 1Gen TSX
I see that the 2 Gen TSX has a switchblade key
Does anyone know if a 2 Gen TSX key can be programed to work on a 1 Gen TSX ?
Old 10-03-2008 | 05:02 PM
litesout's Avatar
Oliver!!!
In short, no. Different immobilizers and different keyless entry remote. It's also a laser cut key, so like the 07 TL key, you'd have to have it milled and cut.
Old 10-04-2008 | 11:33 AM
ABP_04TL's Avatar
6-SPEED LOVER
nuttin in this world is IMPOSSIBLE...
trust me its possible 2 do, cuz the TL 07-08 key is laser cut and i have it cut for my 04
Old 10-04-2008 | 11:58 AM
MMsTSX's Avatar
JDM Addict
no, it's not possible.
you obviously don't understand how our cars work.
an 07 TL key is what you want to make the mod out of.
and 09 TSX will NOT work.
being a laser cut key is not the problem.
Old 10-04-2008 | 02:43 PM
litesout's Avatar
Oliver!!!
Exactly. As I stated in my earlier post, they use different immobilizers and different keyless entry remotes. The 07 TL uses the same immobilizer and same keyless entry remote as the 1G TSX. Oh and by the way, I have the 07 TL key for mine too.
Old 10-05-2008 | 01:57 AM
samnguyen's Avatar
i had the 07 TL key for mine too, but can't get the freaking remote to work.
Old 10-05-2008 | 02:20 AM
MMsTSX's Avatar
JDM Addict
PROGRAMMING THE REMOTE TRANSMITTER (KEYFOB)
Storing transmitter codes.
The codes of up to three transmitters can be stored into the keyless receiver unit memory. (If a
fourth code is stored, the code which was first input will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the
hood and the trunk lid are closed. The symbol (II) denotes the on position of the key where the
double I (II) symbol is stamped on the ring surrounding the ignition lock.
1. Turn the ignition switch ON (II)
2. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at
the keyless receiver unit behind the driver’s side of the dashboard.
3. Within 1 to 4 seconds, turn the ignition switch OFF.
4. Within 1 to 4 seconds, turn the ignition switch ON (II).
5. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at
6. Within 1 to 4 seconds, turn the ignition switch OFF.
7. Within 1 to 4 seconds, turn the ignition switch ON (II).
8. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at
9. Within 1 to 4 seconds, turn the ignition switch OFF.
10. Within 1 to 4 seconds, turn the ignition switch ON (II).
11. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed
at the keyless receiver unit behind the driver’s side of the dashboard.
12. Confirm you can hear the sound of the door lock actuators within 1 to 4 seconds, then push
the transmitter lock or unlock button again, or the code will not be stored.
13. Within 10 seconds, aim the transmitter (up to two additional ones) whose codes you want to
store in the keyless receiver, and press the transmitter lock or unlock buttons. Confirm that you
can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and remove the key.
15. Confirm proper operation with the transmitters.
NOTE: Once the programming mode is entered, the remote button must be pressed a second time.
If the button is not pressed, or if the ignition switch is turned OFF, the programming for all
remotes will be cancelled.
Old 10-05-2008 | 08:11 PM
samnguyen's Avatar
i tried all those steps, but still counldn't get it to work, somehow my damn car won't cycle. so can't program the remote.
Old 10-06-2008 | 01:25 PM
V-TSX's Avatar
Thanks for the input
I guess the short answer is no
I will have to look into the threads about mods on the TL key
Old 10-08-2008 | 03:28 PM
litesout's Avatar
Oliver!!!
I had this issue with mine. The instructions are pretty poorly written in this regard. When they tell you to turn the ignition switch to "Off" they really mean turn it to "Accessory." Basically, put the key in, turn it to the "On" position but don't bump the starter. Next, press the button on the remote. Next, turn the key one position counter clockwise to the "Acc" position. The radio should stay on when you do this, and you do not have to push the key in to get there (if you have to push the key in, you've gone too far.) Turn the key back to the "On" position. Push the button on the remote. Do this a total of 4 times and you should hear the locks cycle. Follow the referenced instructions from there.
And by the way, when they say you have 10 seconds to register all of your remotes, they're not kidding. It took me a few tries to get to all 3 when I did mine.
Oh, and I almost forgot. What year is your TSX? If it's an 04/05 the remote might not work right after programming. If it doesn't, hold the lock and unlock buttons until the light flashes to unlink the memory seating and it should work fine.
Last edited by litesout; 10-08-2008 at 03:31 PM. Reason: Add info for 04/05 users.
Old 10-08-2008 | 04:28 PM
davidspalding's Avatar
Make a hole, coming thru!
Lightbulb
Someone ought to document this procedure, with the correction by litesout, as a DIY ... if not already done so.
Old 10-08-2008 | 09:37 PM
samnguyen's Avatar
thanks man, i hold the lock and unlock too, but still not working, so I just gave up. (2005 TSX)
Old 10-09-2008 | 12:46 PM
zoomspeed05's Avatar
i have a tl key as well i mod the key with one of my spare keys and its beautiful its the best mod ive done to my whip
Old 10-09-2008 | 03:04 PM
litesout's Avatar
Oliver!!!
Are you sure you've got a TL key? Does it start the car? What's the FCC ID on the back of it?
Old 10-09-2008 | 03:45 PM
samnguyen's Avatar
i'm pretty sure i got the TL key, cause i went to the dealer and asked for a 2007 tl key. so. FCC: ID ML BHLIK - 1T
Old 10-09-2008 | 04:03 PM
litesout's Avatar
Oliver!!!
Hmm, that's odd. My FCC ID (as well as a few others here) is OUCG8D-439H-A. I'll have to have a look at that. You're getting it off the back of the key (above the directions for lock and unlocking the memory seats) or are you taking the remote off the key and getting it from there?
Old 10-10-2008 | 09:38 PM
samnguyen's Avatar
no, i got it from, right below (DRIVER 1). In the back of the key. so I need to make a copy of your FCC: and go get another key.
Old 10-11-2008 | 04:39 PM
litesout's Avatar
Oliver!!!
Hmm, the FCC info on all the TL keys I've ever seen is the very top line. The Memory 1 is the bottom line with a picture of a seat below it. I'd wonder if you got an American TL key, but Acura only exists in North America. They're relased under the Honda name everywhere else in the world.
Old 10-11-2008 | 05:06 PM
litesout's Avatar
Oliver!!!
Okay, going off that FCC ID you gave me, that's not a TL key. It looks more like a Civic or Accord key. The TL key is a "switchblade" type key. The key itself folds back into the fob and locks into place. Then when you push a button at the top, it springs out.
Old 10-11-2008 | 05:11 PM
MMsTSX's Avatar
JDM Addict
agreed.
my number is:
OUCG8D-439H-A
p.s.
NEVER, EVER go to the dealer for ANYTHING besides
warranty work, or say oil changes.
if you want an 07 TL key, blank, buy it off of ebay.
Old 10-11-2008 | 11:14 PM
samnguyen's Avatar
that's exactly what I got. I walked into the Acura dealer and asked for a 2007 TL key. Its has a button on the top too. (switch blade). So that F****ing guy at the part dept. gave me the wrong key.
Old 10-12-2008 | 03:27 PM
litesout's Avatar
Oliver!!!
Can you post a picture of your key? Where are you located, BTW? US, Canada?
Oh, you know what, I think they changed keys mid year. If I remember right, the early 07s (built in 06 and the early part of 07) don't have the switchblade key. I think it was a mid model year revision. I remember reading that somewhere, just don't remember where.
And you're actually better off buying them from a private party who's already milled the key. The TL key is very different from the TSX key and has to be modified to work with our cars. The keyblade has to be milled down to size and the grooves have to be milled in order for it to work.
tsx_boy
12-13-2019 08:33 PM
soupi
14
11-15-2015 11:15 AM
eastcoastguy
10-29-2015 03:00 PM
malvothegreat
09-29-2015 12:38 AM
Sue1910
2G CL Problems & Fixes
09-27-2015 12:34 PM
Quick Reply: 2Gen TSX Key on 1Gen TSX
