2008 TSX Glove Box Cant Open Issue
Subscribe
Feb 11, 2013 | 07:58 PM
Any one have issue for your TSX Glove Box Cant Open?
Before it was hard to open it. Need to push and pull the handle Then OPEN>
NOW is dead cant Open it .
Any One have that issue to fix it ? and how to remove it out too see the lock
Reply 0
Feb 12, 2013 | 04:54 PM
Any one know how to remove the lock out ? PIC
Reply 0
Feb 12, 2013 | 04:56 PM
Reply 0
Feb 14, 2013 | 10:12 PM
Any one ? my is 08 TSX a lot problem
Reply 0
Feb 15, 2013 | 06:47 AM
The lock is integrated so that would require replacing the entire box. My '08 box was hard to open, too, so I gave the lock/hinge a shot of lithium grease which solved the issue.
Reply 0
Feb 15, 2013 | 07:50 AM
When my glove box became impossible to open the dealer replaced the glove box. It was under warranty so free for me.
Reply 0
Feb 15, 2013 | 10:23 AM
Door won't open because handle won't pull or release doesn't clear door latch? It might be possible to adjust the latch position slightly.
If door release doesn't move suggest a good shot of WD40 to hopefully loosen movement. Perhaps even excercise the key (perhaps key pin did not retract?)
good luck
Reply 0
Feb 15, 2013 | 01:45 PM
Quote: When my glove box became impossible to open the dealer replaced the glove box. It was under warranty so free for me.
when you replaced it ? 06 TSX ? still in warranty?
My is 08 i think is out of warranty
Reply 0
Feb 15, 2013 | 01:48 PM
Quote: The lock is integrated so that would require replacing the entire box. My '08 box was hard to open, too, so I gave the lock/hinge a shot of lithium grease which solved the issue.
My is jammed I think the lock inside is broken
Reply 0
Feb 15, 2013 | 01:49 PM
It was an 06 so during it warranty time which my case within the first 18 months as it had 50k miles by then.
Reply 0
Feb 15, 2013 | 01:59 PM
Does the dealer Still Cover my 08 TSX with 45000 mile ?
Reply 0
Feb 15, 2013 | 02:16 PM
Quote: Does the dealer Still Cover my 08 TSX with 45000 mile ?
Warranty is 4yrs/50k miles. You are probably out of warranty due to age.
Reply 0
Subscribe
