2006 part interchangability
Old Jan 30, 2006 | 04:43 PM
Black_6spd's Avatar
VSA Rocks
According to the Road and Track article below, the 2006 has the following improvements over the 04/05 models:
- 64 mm throttlebody (previously 60 mm)
- larger intake valves
- higher lift / duration intake cam lobes
- larger header downpipe
- high-flow catalytic converter
- drilling to block design to reduce cylinder-to-cylinder pumping pressures
Does anyone know which parts are possible to be interchanged? Would any of them be worth it? By the looks of it, the high-flow cat, header, and throttlebody might have the ability to be interchangable. Who knows at what cost...
Old Jan 30, 2006 | 05:22 PM
moda_way's Avatar
I've looked these parts up and yes, they are different, specifically those, but they missed a few too. The intake was honed in a few areas to help flow that extra air.
Vtec.net reported on a test with the much larger TL TB and saw minimal gains.
1. Yes the TB is larger
2. Yes the intake valve is bigger, but the exhaust is the same (valve springs are shared with the RSX Type S), not the case with 04-05 models.
3. Yes the intake cam only is new
4. Yes the header is new as well.
5. Yes the cat is new to the 2006
6. No idea if they drilled, but the block is definitely a different part number.
So the question is, would the cost for parts be prohibitive... answer is..... yes
If you want more usable power for the same cost, do the CAI, hondata, or better yet, do the Comptech S/C.... assuming you have a 2004. You would need the new ECU (which I doubt could be transplanted) to have the correct fuel mappings, otherwise, more air makes it run leaner, which will get you more power, but more heat too and possibly damage your current engine.
All this was confirmed (parts wise) to the parts catalog.
moda_way and JTso tend to be kill joys... waiting to hear what he has to say.
Old Jan 30, 2006 | 07:03 PM
Black_6spd's Avatar
VSA Rocks
Actually, when I heard about the larger throttle body on the '06, I was thinking of JTso. I wonder if a different bore dia was the only difference in the new TB? If so, it should fit with some port work like he did.
I guess its wayyyy to early for anyone to have tried any of this, too.
btw - I have an '05 model and seeing our (2) supercharged members has really got me itching to do something beyond the typical I/H/E bolt-ons available.
Old Jan 30, 2006 | 07:05 PM
Black_6spd's Avatar
VSA Rocks
Yeah, but JTso reported CAI-like gains on his TB mod, right?
Old Jan 30, 2006 | 08:21 PM
moda_way's Avatar
Only TB mod I've seen from him is the coolant bypass and there is no HP to gain from that, just maintaining what you have.
Again, you'd have to open up your intake manifold too if you do the TB and the Intake manifold is different on the 06.
FYI, you can still do the S/C, just need to get an 04 ECU and have me do the key mod for you. I'd say that is cheaper than buying the 06 parts for a few extra hp.
Old Jan 30, 2006 | 09:09 PM
kyotousa's Avatar
if youhave those money to change parts...you should just get after market kits...
perform better anyway
Old Jan 30, 2006 | 10:36 PM
Black_6spd's Avatar
VSA Rocks
https://acurazine.com/forums/showthread.php?t=22491
Old Jan 31, 2006 | 06:57 AM
moda_way's Avatar
^^I don't know how I missed that.
Old Jan 31, 2006 | 07:07 AM
moda_way's Avatar
Getting a new TB is going to be around $570 alone, so I would say doing your own TB mod from JTso would be more cost effective IF you don't screw something up.
A new gasket is only $3
Old Jan 31, 2006 | 07:29 AM
moda_way's Avatar
I think this is why I didn't bother doing the mod....
http://www.hondata.com/tuning_the_tsx.html
Old Jan 31, 2006 | 09:24 AM
Black_6spd's Avatar
VSA Rocks
This is what I suspected. Currently not worth the effort.
When I originally raised the question to the AZ community, some of my curiousity was for the long term. I can easily see ITB's being created in addition to more '06 owners buying headers, aftermarket cat's, etc due to FI availability. This would translate into what eventually developed for the B-series owners: A huge market for OEM parts.
Just curious, what resource are you using to obtain part numbers and prices?
Old Jan 31, 2006 | 12:27 PM
moda_way's Avatar
I have access to an online Honda NA catalog. I use www.acuraparts247.com to get the prices.
gehrlichman
Sep 22, 2015 10:08 AM
hand123
Sep 10, 2015 09:29 AM
hand123
Sep 10, 2015 09:27 AM
