2005 TSX...Can You Install The OEM Bluetooth??
So I Have a 2005 TSX W/Navi and I was wondering if it was possible to instal the Stock 2006 Bluetooth Phone Kit in the car. Will the dealer install this in my car? If so...How Much?..Also what parts are needed to do this addition?..Do you have to mess with the Navi Software?..I searched and couldnt seem to find anything.
Its gonna get ridiculously pricey,
You have to get the bluetooth module + the 06 dash cluster with the MID display which is expensive. Plus other wiring that may or may not be compatible.
Parrot Bluetooth kit or other aftermarket kits are probably a better choice.
They can set it up so that when you have an incoming call, it will mute your radio, the mic can be wired up and fed along the A-PIllar, and the module can be placed where your "Not an Ashtray" cubby is so its pretty integrated IMO.
NotQuiteRite (07-28-2012)
I bought and installed the GROM-Audio iPod/USB/Bluetooth unit. It allows me to play Bluetooth Audio back through my phone wirelessly through the factory head unit. It also came with a microphone that is hooked into the unit that can be run somewhere in the car, which I installed in the bin below the Nav/Radio. When I make a call, I simply open the bin and have a normal conversation. No one ever complains that they can't hear me and its like having real Bluetooth in the car. The steering-wheel controls even work for the use of making/ending a call. I'll take some pictures if interested.
handsom-hustla
11-13-2015 05:04 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
