2 fold question on displayed temperature
Old Jun 7, 2006 | 10:21 PM
Reach's Avatar
OK, I've noticed my temp sensor is consistently ~5 degrees (F) too hot this spring/summer. I found this useful thread: (http://www.acura-tsx.com/forums/showthread.php?t=6752) on how to adjust the readout.
1. Has anyone done this on a 2006 and can confirm it works? (I have navi, don't know if that makes a difference since its in the MID) Also, is it tied to 'Driver1' / 'Driver2' like most settings? I use an accord key and can't utilize these features.
2. Has anyone relocated the outside temp sensor to somewhere other than next to the radiator? (what an odd place anyway) This I could not find anything useful in search. I don't see any reason why I couldn't put it somewhere more useful, like next to my CAI air horn, to get a better outside temp reading.
I'd really like to move the sensor. Can someone post scans of exactly where it is and how to access it? I assume I can just extend the wires and tuck it away somewhere more useful. Having it read next to the air horn seems logical since that's the temp of the air the engine is getting. Thanks.
Old Jun 7, 2006 | 10:24 PM
JTso's Avatar
It's right behind the license plate.
Old Jun 7, 2006 | 10:43 PM
Jeff The Pianist's Avatar
front or back plate?
Old Jun 7, 2006 | 10:45 PM
JTso's Avatar
front
Old Jun 8, 2006 | 05:53 AM
Dan Martin's Avatar
Photography Nerd
Just FYI, update your bookmark to tsx.acurazine.com instead of acura-tsx.com because I'm not sure how long acura-tsx.com will be alive.
Old Jun 8, 2006 | 07:22 AM
LoveMyTL-S's Avatar
Originally Posted by JTso
front
Some of us don't have a front plate.
Old Jun 8, 2006 | 08:10 AM
Dan Martin's Avatar
Photography Nerd
more correctly, it's behind the front bumper, behind the front plate.
Old Jun 8, 2006 | 08:11 AM
xizor's Avatar
Bye TSX, hello domestic?
I think he means behind the front plate, inside the bumper cover directly back from it
Old Jun 8, 2006 | 10:01 AM
jpt's Avatar
jpt
In that case, your temperature sensor is at your local motor vehicle department
Old Jun 8, 2006 | 10:09 AM
IlliNorge's Avatar
Benchwarmer
I've noticed the temp to be just about exactly on target, maybe 1 degree too high. You definitely have to drive for about 6-8 minutes before it reaches the correct reading. I've noticed that bank readings are always a few degrees higher than radio or Weather Channel temps, probably because the bank signs are in the sun and the weather channel info is 15 minutes late and shaded.
Old Jun 8, 2006 | 12:25 PM
JTso's Avatar
The ambient sensor is item # 3.
Old Jun 9, 2006 | 06:06 AM
LoveMyTL-S's Avatar
Yea I know....... Was just j/k
Feb 25, 2020 09:57 AM
Type S Zero
Feb 17, 2016 02:37 PM
Puma Jim
Sep 26, 2015 01:08 AM
Sep 13, 2015 01:59 PM
datadr
Sep 12, 2015 09:12 PM
