07 tl key fob mod question
Old Mar 6, 2007 | 12:17 PM
mltk53's Avatar
I can't find my garage
i remember when the tl keys were announced and people were all getting into it, i read somewhere that when u go to get the immoblizer programmed to work with car, you have to take all your keys, the driver 1, driver 2, and the vallet. is this correct? i tried searching where i read that but i just cant find it.
Old Mar 6, 2007 | 12:24 PM
rza49311's Avatar
I don't believe thats true. I'm pretty sure you just need to take the new fob and they program it to match all your other keys.
Old Mar 6, 2007 | 12:35 PM
moda_way's Avatar
^^Correct.
You only need the key that you want the ECU to find and it has to be cut so that it will work in the ignition. That's it.
Old Mar 6, 2007 | 01:02 PM
SHYUperman's Avatar
J M U ... DUUUKEESSSS
typically, how much does the dealer charge for cutting the key, programming it, and etc?
Old Mar 6, 2007 | 01:08 PM
rza49311's Avatar
https://acurazine.com/forums/showpos...postcount=1295
Old Mar 6, 2007 | 02:30 PM
cibs's Avatar
*shrugs, i had to bring all mine to the dealer to get it programmed so they would all work...
thats' what they said anyways...
Old Mar 6, 2007 | 02:32 PM
DAYTA's Avatar
Originally Posted by moda_way
^^Correct.
Sorry, but I believe you guys are wrong.
The OP is correct - you need to have all your keys present when reprogramming your immobilizer.
The programming tool that the technician will use essentially resets your immobilizer. Consequently, each key that you plan to use with your car has to be relinked to the new code in your immobilizer.
I have personally had this done to my car, so I know you'll need all your keys present when reprogramming the immobilizer. If you want further proof, check FLBusa's thread in the BM. Other people have confirmed that this is the correct procedure.
Old Mar 6, 2007 | 02:40 PM
CGTSX2004's Avatar
Actually, this depends upon the programmer being used by the locksmith to program the key.
For dealerships, they use the HDS programmer, which will allow you to simply add one key to your existing keys.
For everyone else, they use a programmer that is compatible with Honda's data system, but is not the exact same HDS programmer that is used by the dealerships. For these, you need to bring all keys to ensure that they all get programmed.
Clear enough?
Old Mar 6, 2007 | 02:49 PM
DAYTA's Avatar
Great, so everybody's right ......
Old Mar 6, 2007 | 02:57 PM
04tsxxx's Avatar
i (hopefully ) will have my key soon and im worried about the hondata ecu and the dealership..... its not gonna pose a problem with a reflashed ecu is it? i hope not. i know hondata burned my stock ecu and redo my key but i dont know if that was pre flash or after.....
Old Mar 6, 2007 | 03:10 PM
CGTSX2004's Avatar
Or better yet, everybody was wrong..
Old Mar 13, 2007 | 02:09 PM
mltk53's Avatar
an update.
so i took my key to a local locksmith and they said that they werent able to recognize the transponder on both the oem tsx key and the tl key with their machines. whats going on? is it just that their computer/machine or w.e is old and unable to identify the high tech keys?
Old Mar 13, 2007 | 02:19 PM
JTso's Avatar
Clear enough?
Actually, when I got a spare key made at the dealer, they want all the keys at the same time. If I didn't have all the keys, they will not gurantee the rest of the keys will work.
Old Mar 13, 2007 | 03:14 PM
jaehshim's Avatar
I got my KEYS done a month ago (06 TSX keys to TL Switchblade keys)
they made sure i bring all my keys to the dealer, all the immobilizer in each key has to be re-done at the same time.
everything works perfectly, along with my new TL key that was done as "memory 1 key"
finally, me TL key, 06 TSX Memory 1 key, TSX Memory 2 key and spare key ALL works .
it was a great service, the dealer had done some other Acurazine members the same mod.
they charged 48.00.
but u need to find cheaper dealer, some other local Acura Dealer asked 150 ~200 for the keys done.
Old Mar 19, 2007 | 11:37 AM
04tsxxx's Avatar
anybody with a tsx have problems programing the remote? instructions are seemingly easy and everything goes kine by line , but when i shut down unlock on the switchblade will not function. everything else i programmed works perfect. even lock and truck on the switchblade. HELP!
Old Mar 19, 2007 | 11:51 AM
jaehshim's Avatar
i think the best/fastest way is to just simply bring it to the dealer and let them figure it out
technically, the remote should work fine (unlock,lock,trunk).
where did you get the key cut and (immobilizer)programmed?
if you got them at a dealer, you shouldn't have any problem.
Old Mar 19, 2007 | 01:13 PM
CGTSX2004's Avatar
Assuming you have an 04, just follow the instructions on the back of the key to unlink the transmission of the memory seat info.
Old Mar 19, 2007 | 01:48 PM
04tsxxx's Avatar
dude....you da freakin MAN! problem solved.
Old Mar 19, 2007 | 02:02 PM
Mokos23's Avatar
check this out
http://www.youtube.com/watch?v=_DXPQj54IUI
Old Mar 19, 2007 | 09:59 PM
Rocket_man's Avatar
Summer is Coming
an update.
I had to go to two locksmiths.. from what I can tell, the locksmiths need to buy "upgrade" modules for the newer Honda locks. If they don't have the right adaptor the device won't work. The first locksmith seemed to have the right adaptor but when he plugged it into my car it did not recognize the system. He mentioned they had bought the upgrade and didn't know why it wasn't working. The second place I took it to had no problem.
From some dealers responses, I think they are actually using one of these locksmith devices to program the keys. I'm not sure if they don't realize that they can do it with the HDS, but one local Acura dealer told me I'd have to bring the car in on a day when they have the programmer. Maybe they have a locksmith do it, since they wanted to charge me $109 and a locksmith does it for $40 maybe that is some quick profit for them. So this may be why some dealers want you to bring in all your keys. If the HDS is used it can ADD a new key by looking up some special code, if a hand-held key programmer is used it OVERWRITES all the keys so each one has to be programmed (and of course you need to bring all your keys).
Old Mar 19, 2007 | 10:06 PM
daicacharco's Avatar
soo, cant i use the steps that moda_way had listed to get the chip to connect to the immoblizer to get the key to work?
Old Mar 19, 2007 | 11:26 PM
CGTSX2004's Avatar
No, the instructions that moda_way put up were to program the remote, not the key.
Old Mar 19, 2007 | 11:32 PM
CCColtsicehockey's Avatar
Originally Posted by 04EuroAccordTsx
there you are with a youtube link again
Old Mar 20, 2007 | 05:30 AM
moda_way's Avatar
You only need 1 key. My guess is the dealership doesn't want to accidently erase a key, so they test them all after they add a key. Here is the actual procedure directly from AllData.:
Procedure
1.Use an appropriate key blank and a suitable code key cutter to cut a new ignition key (see S/B 99-010, Cutting keys With the Exacta Code key Cutter).
2.Connect the HDS to the 16P data link connector (DLC).
3.Insert a programmed ignition key into the ignition switch, and turn the switch to ON (II). Turn on the HDS.
4.At the screen prompts, enter the VIN and the odometer reading, and then verify the correct date and time.
5.From the System Selection Menu screen, select IMMOBI.
6.From the Mode Menu screen, select Immobilizer Setup.
7.From the Immobilizer Test Mode Menu screen, select Add and Delete Keys.
8.From the Add and Delete Keys screen, select Add 1 Key.
9.From the Add 1 Key screen, select Begin to add 1 key.
10.From the 1st Password screen, enter the 1st Password, and then follow the screen prompts. When you are finished, turn the ignition switch to LOCK (0), and then turn oft and disconnect the HDS.
Old Mar 26, 2007 | 09:59 PM
ncsu-tc's Avatar
Probably a dumb question, but can you have 2x memory 1 keys?
Old Mar 27, 2007 | 12:53 AM
mltk53's Avatar
im pretty sure u can as i use my oem one and the tl one. both beign "memory 1" keys
Old Mar 29, 2007 | 07:48 PM
TDK920's Avatar
4th Gear
I see that you are in So Cal.
Did you have your key done at the dealer?
If so, which dealer did you take it to????
Old Mar 30, 2007 | 12:24 AM
mltk53's Avatar
santa monica acura dealer. and honestly, i REALLY dont remember anything about it.lol i think i paid around 60dollars and i had all my keys and i dont remember if they needed all of them.
Old Mar 30, 2007 | 11:00 AM
TDK920's Avatar
4th Gear
well, when I called them, they said they can't do it.
Did you have blank key or milled key??
Old Apr 17, 2007 | 01:17 AM
slvr06tsx's Avatar
tommy13
can anyone tell me how i can contact fbusa so i can buy the milldown keyfob from him thank you
Old Apr 17, 2007 | 05:11 AM
moda_way's Avatar
Look in the Groupbuy section of Black Market. Or you can PM FLBusa.
Old Apr 17, 2007 | 07:30 AM
slvr06tsx's Avatar
tommy13
hi moda thats the problem for some reason i cant pm anyone it says my account is restricted or something like that
Old Apr 17, 2007 | 07:37 AM
DAYTA's Avatar
You haven't reached the required minimum amount of posts to PM yet...
Old Apr 17, 2007 | 07:42 AM
slvr06tsx's Avatar
tommy13
i figured that might be the problem thanks for the help i have already emailed him through the black market forum sorry for being such a noobie here
Old Apr 17, 2007 | 01:30 PM
TDK920's Avatar
4th Gear
I just got a milled TL Key Fob from FLBusa!!
It was pleasure dealing with him.
Thanks again FLBusa!!
Old Apr 23, 2007 | 11:57 AM
slvr06tsx's Avatar
tommy13
help with a local locksmith
does anyone here know of any locksmith located in bensalem, pa that can program the immobolizer , i have called my local acura dealer here and they said they would not touch it i told him its an original acura 07 tl key but he still wouldnt do it so i need help
Old Apr 24, 2007 | 09:31 AM
slvr06tsx's Avatar
tommy13
selling my 07 tl keyfob
ok guys i have giving up on this mod i have tried going to a couple of locksmiths and acura dealers none of them is willing to cut the key and programmed to the immbolizer so i'm selling it i will be posting it on ebay today if anyone is interested you can email at trinh3443@comcast.net. i bought the key from fbusa just last week nothing has been done to the key on my end
Old Jul 20, 2007 | 07:42 PM
msmching's Avatar
Ex-King of Pasadena
Thread Alive again.!!
So HI to anyone LOOKING at this.
I just got my TL key.. and it's something that ppl called "Blank" on it. And i m wondering if anyone know where can i get the "milled" key?!?!
I m Pasadena, california by the way.
THANKS!!!
Old Jul 21, 2007 | 11:24 AM
mikeucla's Avatar
contact flbusa or look on ebay for listings from aofe (acura of escondido). since you're socal you may even want to drive down there
Old Jul 21, 2007 | 12:11 PM
LOL888's Avatar
damn getting the beep interests me more than the key =(
