'06 Foglight Operating Question
Is it normal for the foglights to only turn on when the regular lights are on? As in when the low beams are off the fog lights do NOT turn on even when the switch is in the ON position (no dash indicator either). The foglight indicator and the lights themselves will work if the low beams are ON. Is this normal? Sorry I am a noob to this car/ these things...
it's normal. clearly stated in the manual.
just kidding about the RTFM, but seriously, read the manual, then come to the board with anything you dont understand or want further explanation.
it's not that people don't want to answer questions that the manual answers, it's that you should read it because it will tell you almost everything about your car, then acurazine will add to that knowledge!
Originally Posted by jasonviper04
OK well how do you get the fog lights on without the headlights on???
2. i believe i answered that above by saying it's normal to the following question: "Is it normal for the foglights to only turn on when the regular lights are on? "
Originally Posted by bradykp
1. why would you want to?
, they ain't there to light up just because you have them
, and you would never need them on when the headlights are not on!
And I know its normal but there has to be some way to do it right?
Originally Posted by DuckDodgers
3. There is no reason, other than fog or poor lighting to the side of normal headlight illumination, to use foglights. They ain't cool
i think you meant to say what i corrected in bold
Because it just looks cool. And if I just want the foglights on lets say when its raining outside or its dusk just for other drivers to see you then I want to be able to do so you know.
it doesn't look cool at all, since it's vaguely visable, and it's not normal, and there's no way to do it, without changing the wiring.
nope, because as stated above, there is no reason to use fog lights unless there is fog. they aren't really visable to other drivers since they are on the bottom. they are to illuminate the road and sides of the road. in most states, if it's raining you're required to have headlights on. and you should anyways because it's commom sense.
It doesn't look cool at all, since it's vaguely visable, and it's not normal, and there's no way to do it, without changing the wiring.
3. There is no reason, other than fog or poor lighting to the side of normal headlight illumination, to use headlights. They ain't cool
I used to do a little media work (filming/video editing) and the first thing they teach you about lighting is not to mix types of lights, specifically halogens (yellow/warm) with florescents (white/cold). And yes I realize that cars and videos are two different topics. On the other hand, they say that 'beauty is in the eye of the beholder'... so if you like it go for it, and if you like just fogs, go for it... but you can't.
Are you serious I can see a car with just there foglights on from at least a 1/4 mile away hell for the matter I can see a vehicle with just there parking lights on from a 1/4 mile away at night. I think they are very visible. It kinda defeats the point of having fog lights if you can't have them on without the headlights because the last thing you want on during dense fog is your headlights its kinda scary when you see them reflecting back at you.
fog lights are pointed at the ground, it's pretty good if you see them from 1/4 mile away, but i don't believe it. also, i am pretty sure most cars the fog lights don't go on without the headlights.
Originally Posted by clearlycanadian
I disagree. Having only fogs on might confuse other drivers as to your distance (esp dangerous in single lane highways when people want to pass in your lane). For example you may know what I mean if you've ever seen a single light in the distance and assumed it was a far away car but then it passes you sooner than expected because it actually was a car with only one working headlight. To be fair I've never seen just fogs on so maybe i am talking out of my
Look, all discussion of usefulness and coolness aside, I think what he's getting at is HOW TO RE-WIRE IT which is a legitimate question.
Its also one that hasn't been how-to'd here or fully answered to my knowledge so let him ask.
The half-ass answer is you'll need the Helms electrical manual to figure out where to tap the fog light on/off signal from the stalk, and disconnect it from the headlight wiring, and see if you can supply it with a nice 12v constant and let the stalk do the switching. I have no idea if its even possible, but someone with the electrical manual could tell you.
Personally, if you want to, why not.
is it possible to rewire, yes. is it worth the effort since it's difficult? that's for you to decide.
the second question should be addressed in a new thread, so he can get that feedback from people who know how to do it, but the feeling i've got from other threads that already discussed this is: don't bother.
Originally Posted by CGTSX2004
This one has been discussed ad naseum. The wiring is arranged in such a way that this would be prohibitively difficult to do. You're welcome to try, but you'd pretty much be the first.
I have been looking to do this as well. I have not had the time to get back to the project yet. This is what I have found out so far. There are 4 contacts points where the fog light relay is. AS soon as the car is started two of the contacts are 12v hot. This tells me the steering stalk provides ground to turn to turn the fogs on. So the two contacts that are not hot, go to the hot side of the fog light and the other is the ground from the stalk. I think all you have to do is ground one of the contacts( the one from the stalk) and the fogs should come on. Install a switch between this wire and you should be able to turn them on and off. In the off position you can use the light as normal with the headlights. I am going to try this when I get time.
navtool.com
31
Nov 16, 2015 08:30 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
