04 TL engine in a TSX?
Engineer
i am not sure if it would fit, but it seems too costly, i have seen it done in a lot of cars when it is known the the original engine can not handle more power from mods very well, one example is new m3's where the engine cant handle too many mods without blowing up, so people drop in M5 engines, lots of money though...
a turbo kit with intercooler on the 2.4 would produce more power, be lighter and a lot less expensive...
also i believe comptech has a supercharger coming in the near future...
Bye TSX, hello domestic?
Originally Posted by roughrider
Is it possible to fit a complete 04 TL engine + tranny in a TSX? I am just curious.
It's Major. Boy.
Originally Posted by xizor
as for the price for replacing the engine/transmission you probably could've bought a TL in the first place.
Let say money and parts are not the issue.
hard to say ... that dude is huge for our engine chasis ... and the design is totally diff.
like our eninges are intakin in the front and exhaust from the rear and the TL's r oppsite ..
tons of difficulty + pain in the ass .... remeber this is not like swap a Type-R engine in Civic or RSX
the v6 would horribly throw off the balance of the car.....
Moderator Alumnus
I'm pretty sure the weight increase doesn't exceed 150lbs. Not enough to make a "horrible" difference, IMO. Just make sure then that you have the A-Spec package. Should take care of things.
Registered AssHat
yeah ......... both Supercharger and Turbo will get u the power to kick TL's ass and ALOT less money for the parts and installation... and less risk to fuk ur car up .. ~~
if it work .. u r lucky .. if it doesn't ,.... then u really fucked ~
It's Major. Boy.
Originally Posted by bgillette
this is the dumbest idea ever.......
if you want TL POWER get a TL
if you want TSX Power and handleing....get a TSX!
gezzzz
gezzzz
Calm down guys, like I said, I was just curious. Nothing serious. Just shit talk.
gezzzz
gezzzz
But to answer the question -- yes, I do think the J32 from the 04 TL would fit under the bonnet of the TSX.... anything's possible... but clearly, it is an undertaking of gigantic technical proportions. It would require lots of modifications with the possibility of moving other components of the car to the rear and possibly utilize a modified transmission or an entirely different one. Since the J32 is a transversely configured motor, space requirements are already favorable but still doesn't make things any easier since the TSX's shorter front-end seems to be also more sharply raked. It's definitely a shoe-horn job and I've seen even more challenging ones performed successfully in the past so this is do-able. The question is, why? when there's better alternatives, and even better motors available that are even more compact. I don't think this one is worth doing which is why you'll never see it go past the "what if" threads on forums like these.
Its not a dumb idea because if it was feasible people would do it. Just like someone mentioned the BMW and civics, this is all about moding your ride not buying a stock car.
My friend had a 3 series with a 5 series engine and it would wipe any 3 or 5's azz. Just like the audi S4 is an A4 with a big azz engine.
But would the TL engine fit in the TSX's engine bay? I think when the car first appeared, a lot of people were expecting at least the V6 from the Accord, if not the 3.2L engine, and it was almost always brought up that the 6-cylinder engine would not fit.
Originally Posted by Deelover
....My friend had a 3 series with a 5 series engine and it would wipe any 3 or 5's azz......
If a V6 fit in the TSX I'm sure they would have offered one at least in the US and Canada. With the Accord 3L the most obvious choice. But, this car was designed and built with European tastes in mind and thus was only designed to accomodate a 4 banger. Remember that not only would a heavier V6 throw off weight balance but it may also complicate the crash zone of the car as well.
So would it fit? Anything's possible expecially with time and $$$. But you better have lots of $$$
Moderator Alumnus
Originally Posted by ClutchPerformer
So is 150 the actual number? I'm trying to do a calculation here....
The weight difference between the Accord LX (auto) K24 and J32 is 3164 vs. 3349 or 185lbs.
If the K series and the J32 both fit into the Accord then they're presumably using the same mounting points.
The Accord is 2 inches wider and 6 inches longer than the TSX.
The Accord wheelbase is 108" vs 105" for the TSX. It appears as if a fair amount of that additional length is found in the larger trunk of the Accord.
Thus, excluding the slightly narrower and the possibly shallower engine compartment of the TSX, (to be determined) ...it just might fit....
I'm sure swapping in the TL's V6 is "possible" if you have lots of money, have a team of engineers, and if you do some serious modifications to the chassis.
Anythings possible, for example Ford racing crammed a 5.4 liter V8 race engine into a focus and converted it to rear wheel drive. It's in last months issue of Motor Trend. But like everyone else said, its not worth putting the V6 into the TSX. Just buy a friggin TL. What I'd like to see is someone swap a V6 into an S2000. Now that would be interesting.
cycdaniel
12-17-2019 10:58 AM
