Suspension Components from an Accord
does anyone know for sure if the suspension parts from a 1998-2002 Accord fit onto the 2.5 TL's? i read somewhere and heard from a few people that they can be used?
They should fit from what I hear. But be warned that they will not fit a 3.2TL. Been there done that.. Big waste of time and money. But it should be ok if you have a 2.5
Received 2,329 Likes
If I recall on the 3.2 TL, the front suspension is similar to the Legend, but the rear is not swappable with anything else.
'13 Hyundai Sonata
The shocks will actually lower you 0.75" since they are meant for a 4-banger and our cars are heavier.
Then add springs and you will have a sick drop.
At one point, I was looking at Accord shocks with an Eibach Pro-kit so I would of been lower ~2" in the front and ~1.75" in the rear.
Str8 Home built
not all the suspention of the accord will fit lol my bottom balljoint took a dump an i got one for the 94 97 an the little shaft with the thread is too small.. lol.. just thought id throw that out there lol
IIRC, when I bought my B&G coilovers, the box said CL (1st Gen).
I had no problems fitting the struts/shocks on my 2.5.
Only problem was the spring rate was not correct. There was no gaps between the coils. They sent me another pair and it was good.
Still have the coilovers til this day!
Here check this out:
http://www.prostreetonline.com/catal...undcontrol.asp
Part numbers are the same for the CL (1st gen, I'm assuming the 3.0 V6), 2.5TL, & Accord V6 (5th gen)
Call them up to confirm. Good luck!
So there's a guy near me selling his 05 TSX struts, and I was wondering if the springs would fit on my factory shocks okay or should I go with aftermarket shocks if I get them.
mlody
12-04-2019 02:11 PM
SinCityTLX
20
10-19-2015 11:23 AM
lanechanger
10-13-2015 10:56 AM
4drviper
09-23-2015 09:00 PM
