17" 2G wheel problems
Old Oct 18, 2007 | 09:10 PM
M-TL's Avatar
97 3.2 Premium
Hey folks,
I just installed 2nd Gen 17" (5 wide star, 02-03 model) on my 97 3.2 and the car is pulling to the left. I was on stock wheels before (205 65 15) and the car tracked straight. I've got 36psi in the 17" tires (205/50/17) and there is no fit issue with the wheels. Also, the wheels were just balanced and the mechanic said the rims looked straight during balancing. Here's a stock pic of the wheels:
I really don't think it's an alignment issue though I could be wrong. FYI, the handling is noticeably crisper, and the ride is only marginally rougher. Road noise is also up but not too bad.
Anyone have any ideas why it's pulling left, and did anyone put similar wheels on theirs?
Old Oct 18, 2007 | 09:27 PM
VQPower37's Avatar
i dont know what could be wrong, but first gens look hott on the second gen type s wheels ... they almost look like the legend on the second gen type s wheels, which in my opinion looks better than the type s wheels being on the second gen which was the car they were designed for
Old Oct 18, 2007 | 09:31 PM
Phrosttz0's Avatar
why do you have such a narrow tire on those? are the tires new or used? could be the wear on the tires, or its your alignment
Old Oct 19, 2007 | 01:53 PM
M-TL's Avatar
97 3.2 Premium
The tires/rims are used and came as a package. I chose them because I wanted the same overall wheel dimension as stock to avoid any issues with suspension and rubbing. The tires are definitely worn and some showed minor signs of shark teeth on the outside, indicating the alignment was off on its previous car, but not so bad as to cause this much pulling.
Sure, it could be alignment, but it was tracking straight before so I'm confused. Also don't want to spend 70$ for them to tell me the alignment is fine.
Old Oct 19, 2007 | 02:16 PM
heyitsvu's Avatar
OM NOM NOM NOM
Some times when you remount wheels, it can cause an alignment issue. I had that with my car last week when i had my tires rotated. see if you can find a shop who might be able to help/tell you whether it's an alignment issue or not. Or even worse, what if the wheel is bent :o
Old Oct 19, 2007 | 07:35 PM
M-TL's Avatar
97 3.2 Premium
My bad - the tires are 215/50/17 (not 205) - that's what the tirerack website suggested for the 17" wheels for my car.
I don't think the wheels are bent as that would cause some wobble or vibration of the car. I'm going to have to look into it some more. I'll try rotating the tires to see if there's any change. Thanks for the suggestions.
mada51589
Jan 9, 2025 04:40 PM
Zonian22
Nov 14, 2015 01:20 PM
jblessing
Wash & Wax
Sep 17, 2015 09:28 PM
brandnewcolony
Sep 12, 2015 10:39 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
