why do my hid's only work on high beam
Old Jan 4, 2010 | 09:53 PM
fire919's Avatar
how do i fix this....i just installed an h4 6000k hid kit from Halo....but when i turn on low beam there is no light....only high beam...can someone help...any suggestions
Old Jan 4, 2010 | 09:55 PM
tmnhs81's Avatar
Maybe you hooked them the wrong way..
Old Jan 4, 2010 | 11:17 PM
TLin401's Avatar
'13 Hyundai Sonata
Did you ground the HID kit to the battery?
Old Jan 4, 2010 | 11:23 PM
Go90go's Avatar
大日本帝国
It's because the harness was made improperly. Cheap kit...
Anyhow, try removing the spades from the HID harness side of the H4 plug, then switching them around in the three available slots until you find the right combination for the common ground for negative and the low beam positive.
~Cheers~
Old Jan 5, 2010 | 06:40 AM
fire919's Avatar
Thx guys dah 4 quick response....dat switchin wires vibe work Go90go...respect!
Old Jan 5, 2010 | 12:18 PM
Go90go's Avatar
大日本帝国
No problem!
~Cheers~
Feb 25, 2020 09:57 AM
pozebly
Sep 23, 2015 07:30 AM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
