Wheel Stud Replacement?
Old Sep 25, 2010 | 01:59 PM
The Hawk's Avatar
I have a '98 3.2TL and while fixing the rear brakes, one of my wheel studs snapped in half. I know I can drive with 4 studs for a bit but I'd like to fix this ASAP. Does anyone know how to remove the broken stud and install a new one? I'm guessing that it either screws or pounds out? Any help would be greatly appreciated. Thanks in advance.
Old Sep 26, 2010 | 11:36 AM
TexasHonda's Avatar
Stud is pressed into the hub unit. You can tap out w/ a hammer and pull in w/ a lug nut and spacers or a special tool to pull stud into hub rotor. A google search should produce some good examples.
Looks like caliper must be removed & hung-off, rotor removed, axle nut removed, and finally wheel hub can be removed for access.
I looked at some examples and it may be possible to do w/ wheel hub attached to axle.
http://www.youtube.com/watch?v=rU01g...eature=related
good luck
DUECE_DXJ
Sep 24, 2015 04:54 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
cammy5
Sep 4, 2015 11:26 PM
heyitsvic
Sep 4, 2015 09:38 AM
mtl_ilx
Sep 3, 2015 09:48 AM
