CEL P0401 Insufficient Exhaust Gas Recirculation
Old Sep 23, 2010 | 03:15 PM
Mandy's Avatar
98 3.2 Flamenco Black
I am due for an emmission test. The CEL has been on and have not been resolved. I can clear it via my OBDII. But it comes back after 20 miles or so.
Will I be able to pass emmission if I just clear it and have it tested?
Anybody's tried this?
I am going to resolve this issue but am running out of time and I am due for my tag.
Somebody was good enough to send me his EGR valve and I was going to get it swapped but have not done it.
Whadya think?
Old Sep 23, 2010 | 03:57 PM
tmnhs81's Avatar
Nope Mandy, it won't pass if they hook up OBD2 scanner to the car. If it is just a visual for check engine light then it may. Their are certain amount of OBD self test monitors that should be complete before computer gives it a green light of passing inspection. You better get your lazy ass off the couch and change the EGR. LOL
Old Sep 23, 2010 | 03:59 PM
AMUA6's Avatar
ScoobyZINE
Old Sep 23, 2010 | 04:01 PM
tmnhs81's Avatar
Old Sep 23, 2010 | 06:05 PM
DUECEON9ER's Avatar
My pictures didn't help you at all? You can't get around it just pull out the manifold and clean it with brake cleaner, grill cleaner, and carb cleaner.
Old Sep 24, 2010 | 07:13 AM
Mandy's Avatar
Have done that, no go!
I have to get my lazy ass working and change the EGR. Some good fella already sent me his EGR free!
Gotta do it! This weekend, promise.
Old Sep 24, 2010 | 07:16 AM
Mandy's Avatar
Unhappy
Thanks, I thought so too.
Gotta hear this, days ago I walk in to the tag office and handed my renewal papers. They scan it and say have you done your emmissions? I said, I still have valid emmissions. No, they are a 1 time use only. You have to do them 1st and then we can give you your tag....
Needless to say...I walked out with my tail in between my you know what
Old Sep 24, 2010 | 07:21 AM
Mandy's Avatar
That good fella is none other than...TONY!
Old Sep 24, 2010 | 04:48 PM
DUECEON9ER's Avatar
Does the vacuum hose on the EGR hold vacuum though?
Old Sep 27, 2010 | 08:48 AM
Mandy's Avatar
And if it does not?
Old Sep 27, 2010 | 09:11 AM
9632tl's Avatar
Radical Member
The EGR valve itself should hold vacuum, if not, the diaphram is ripped, and the EGR won't open.
Old Sep 27, 2010 | 11:16 AM
Mandy's Avatar
Gotcha. Somebody told me to actually watch that EGR trigger and see if the diaphram triggers.
The EGR runs all the time? What triggers the EGR?
Old Sep 27, 2010 | 12:08 PM
tmnhs81's Avatar
Vaccum. You can do a functional test for egr by pushing on diaphram from the bottom of valve itself. Just put your finger in there and push on the diaphram, if engine dies or starts shaking then egr is fine.
Old Sep 27, 2010 | 12:34 PM
Mandy's Avatar
Gotcha.
Thanks a lot.
Old Sep 27, 2010 | 03:49 PM
Mandy's Avatar
And if it does not anything, then it has to be the EGR?
Old Sep 27, 2010 | 06:13 PM
9632tl's Avatar
Radical Member
Not necessarily. If the pipe TO the EGR is plugged, opening the EGR won't let anything through. It's like turning the water to a hose; you can turn the knob, but if there's no water getting to that valve, none is going to come out the other side.
I hope that made sense
Old Sep 28, 2010 | 07:56 AM
Mandy's Avatar
So if the EGR is pushed and it affects the engine, then EGR is fine. Then my pipes are clogged, right? Just enough to throw a code.
Old Sep 28, 2010 | 07:57 AM
Mandy's Avatar
And if when pushed and EGR does not affect the engine, have to change EGR to check if it will solve it. If it does not then it is the passages.
I think I got it.
Old Sep 28, 2010 | 09:04 AM
9632tl's Avatar
Radical Member
If you open the EGR, and the engine is affected, then there is a problem beteew the vacuum lines and the EGR valve.
My guess is that the supply pipe to the EGR is clogged. NOT the one from the EGR to the intake manifold (because you cleaned it, right?)
Old Sep 28, 2010 | 03:26 PM
Mandy's Avatar
I cleaned the pipe that goes from EGR to the instake and it was not clogged heavily.
Old Sep 28, 2010 | 06:26 PM
DUECEON9ER's Avatar
That isn't going to be enough you have to clean this...
This is behind the egr plate connects to the back of the manifold on one end of the egr tube.
This is how it used to look, not saying yours is the same but similar clogging going on....
Good luck.
Old Sep 28, 2010 | 06:47 PM
9632tl's Avatar
Radical Member
When I took mine apart, that hole was clogged to about the size of a coffee straw
Old Sep 28, 2010 | 10:00 PM
Mandy's Avatar
I know you were going to rub it in...! LOL!
Old Sep 28, 2010 | 10:02 PM
Mandy's Avatar
If there is something I do not like about my TL, this is it! Why did they have to design that crap that way!
Old Sep 28, 2010 | 10:03 PM
Mandy's Avatar
At least they could have told us what to do so that we do not gunk up that crap!
Sorry I am impaired!
Old Oct 1, 2010 | 09:56 AM
Mandy's Avatar
Well guys, luck was on my side yesterday. I cleared my CEL and went to the emmission test station. I passed. 1 mile after leaving the station the CEL came back.
I will debug this CEL. If it takes for me to take to Acura. They quoted me $385.
Old Oct 1, 2010 | 10:22 AM
tmnhs81's Avatar
Did you replace the EGR valve yet?
Old Oct 1, 2010 | 12:03 PM
Mandy's Avatar
Yes! And the CEL came back after 30 miles. I reset and went to the test station and the rest is history.
I have reset it again and so far, 15 miles, no CEL yet. Keeping fingers crossed.
If it comes back, I am taking to the shop.
Biggie_B
May 27, 2025 05:51 PM
samson_420
Oct 8, 2015 01:47 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
San Yasin
Sep 29, 2015 10:52 AM
hrothgar02
Sep 28, 2015 11:08 AM
