turn steering wheel left slight pulsating
Old Jul 13, 2007 | 11:44 PM
tlmadness's Avatar
Going straight no pulsating in steering wheel. Turn slightly right no pulsating. Turn slightly left steering wheel pulsates (best way to describe it) slight vibration.
Had replaced left axle, both rotors and brakes, new tires. Both fronts 30psi. No noise from wheel bearing.
Any insights?
Thanks Madness
Old Jul 14, 2007 | 10:32 PM
KaMLuNg's Avatar
everything is also balanced and aligned im assuming???
Old Jul 15, 2007 | 07:59 PM
tlmadness's Avatar
New tires. No wear on either side, no pull, steering wheel straight. Bought the car used. I would assume if alignment was off would drift to one side and at high speeds steering vibrate. Neither of these occur.
Old Jul 15, 2007 | 08:21 PM
01tl4tl's Avatar
Your tire pressure is about 4 psi lower than most run
The new axle may have a problem
I would do a drain and fill on the power steering pump and system- could be old crud in a small hole messing things up- its simple- search here for DIY
Old Jul 16, 2007 | 08:40 AM
tlmadness's Avatar
Problem existed before the axle was replaced. I replaced axle because boot was really torn.
The power steering I'll definitely read the post on this. The manual said 30psi but tires looked low at 30psi. I'll go to 34psi.
Thanks Madness
Old Jul 21, 2007 | 05:38 PM
demonstrocities's Avatar
7th Gear
Have you checked the driver's side control arm & tie rods? When I had mine replaced, something was loose that was causing a similar problem.
Old Jul 22, 2007 | 12:22 AM
Go90go's Avatar
大日本帝国
^ +1.
Off topic but, 01tl4tl, since you own controlling stock of Seafoam, why in the hell did you guys change your formula? Also, I Seafoamed my C35 that had between 50-70K miles, NO SMOKE. .
~Cheers~
Old Mar 15, 2008 | 12:26 PM
'99TL's Avatar
That was my Jeep :(
tlmadness, whatever happened with this? My girlfriend's car is having the exact problem..
Feb 25, 2020 09:57 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
