Transmission hopes up!!!!!!!!!!!!?????????
If you use car-part.com and search for a replacement, you'll see that only 2.5TL's are donors for transmissions. I've found this site will show X-over donors, if they are compatible. So I think the answer is no.
good luck
good luck
it will not fit
mine has 215k and i just received a used one with 70k on it yesterday. im going to throw it in next weekend. if you need a tranny check out weberbrothersauto.com thats where i got mine from : trans - $250 , shipping - $102 (got here next day!) they still have 3 left (2) with 105k and (1) with 80k something. good luck![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
oh yeah i got the platinum warranty - 12 months unlimited miles for $40
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
it will not fit
thanks
I would be interested to hear how much effort is required to replace the trans. I saw a requirement for a special tool (extension shaft puller). Do you have that tool or alternative method to pull the extension shaft? Do you have a lift or will you elevate the car and remove from underneath?
thanks
thanks
EDIT: wait, you're only doing the tranny? then you don't even need to pull the extension shaft. That's only if you need to pull the differential out without the tranny.
i'm not sure whether we're gonna pull the trans+engine or just drop the trans from below. the guy im going it with is going to bike week, so next weekend this will be done. friday, get started ripping apart. saturday, put all back together. trans along with rear seal, axle seals, everything i see im replacing the seals. the tans i received will also get a new strainer, cleaning, etc.
my alldata print out says you need to pull the extension shaft to drop the trans. being that i usually have GMs and this is my first longitudinal FWD tranny to drop, i'm not too sure which way to try first. also, seeing as how no parts/tool store seems to know what i'm talking about trying to find an extension shaft puller, i'll try the 12mm bolt idea.
got my trans with 40k on it and 2 year warranty for $500. pays to have friends who run a Honda dealership's parts counter.
joflewbyu2
10-08-2015 11:16 AM
