TL won't start..fuel pump??
Old Oct 7, 2012 | 11:07 AM
Smoothac's Avatar
New to the forum so take it easy on me you guys. 98 TL 3.2 will crank but will not turn over. First thought it was the starter turns out that's not the case. Then went to purchase a fuel pump but was told it was the fuel pump assembly that might be messed up. I'm thinking it might be the relay bc when I spray starter fluid it turns right over then stalls out. Seen previous similar threads but with me being new I really just need a step-by-step process to figure out this issue. Anyone can assist me with steps of checking the fuel pump assembly and relay? Thanks!
Old Oct 7, 2012 | 02:39 PM
white2.5tl's Avatar
when you turn the key to acc position, do you hear your fuel pump turn on? if not might be ur main relay.
Old Oct 7, 2012 | 03:26 PM
Smoothac's Avatar
No I don't hear anything. Should it hear a click? Wat sound am I listening for?
Old Oct 7, 2012 | 06:55 PM
main70072's Avatar
^ A hissing sound coming from the fuel tank area.
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
