TL won't start
Old Feb 4, 2006 | 05:05 AM
ALEX WALLACE's Avatar
7th Gear
TL won't start
I have a 1998 2.5 tl today the car would not start i checked the battery it's ok checked the fuse box the 20 amp fuse for the ecu is blown i replaced it and it blew again.
The car dose not attempt to start you dont hear the starter at all but the dash lights and everything else works.
Dose anyone have any ideas?
Old Feb 4, 2006 | 07:55 AM
TexasHonda's Avatar
Do you hear dead silence when you attempt to engage the starter? If yes, then you need to check whether the starter solenoid is receiving power to command the starter. It's a small wire to the solenoid which should supply 12V when keyswitch is turned to START. If no power, then you have a keyswitch problem probably reqiuiring a new keyswitch assembly.
If you do have power, then starter solenoid is bad, since there is no movement when voltage is applied. Solenoid should noisly slam the contacts together to engage the starter.
If you do hear the solenoid throwing, but starter doesn't engage and turn engine over, the solenoid contacts are worn and require replacement or a new starter.
good luck
Old Feb 4, 2006 | 03:25 PM
7th Gear
u were right
Thanks alot i checked for voltage at the starter there was none the blown fuse i found is a part of the cruse control curcuit.
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
