Timing Belt Tensioner '97 3.2TL
Old Jul 20, 2006 | 06:02 PM
wpuryear's Avatar
5th Gear
When removing the lower timing belt cover, I loosened one to many bolts and unattached the timing belt tensioner. Now that I am ready to install a new timing belt, I can't quite figure out how to attach the tensioner spring. The only available post I see is on the left hand side (viewed from front) of the water pump, but that would pull the tensioner in the wrong direction. Can someone help me out cause I'm feeling a little dumb right now.
I assume there are only the four parts - spring, tensioner, bolt, and washer. Did I lose something else?
Thanks in advance,
Walt Puryear
Old Jul 20, 2006 | 07:02 PM
wpuryear's Avatar
5th Gear
Ah, there is hope for me yet - I finally figured it out. The L shaped bracked on the rear of the tensioner is a lever which uses one hole as a pivot point (slid over a protrusion in the casting) and the second hole for the spring which also attaches to the water pump post mention above.
Walt
Old Jul 21, 2006 | 02:49 PM
old_commuter's Avatar
Glad you figured it out - I had no idea what you were talking about, since the hardest thing I'll tackle on my Acura is changing the spark plugs.
Cheers.
vaughanml2
Nov 1, 2021 10:16 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
merc009
Sep 14, 2015 06:43 PM
nash3222
Sep 10, 2015 09:46 PM
