Steering wheel shakes at > 60 MPH
The extra b is for byobb
The steering on my 96 2.5 has always felt pretty lose but now when I get it up to 60 mph the wheel starts shaking/shimmying pretty badly.
Anyone have any ideas what the problem is?
Have all ball jts and tie-rod jts inspected. A loose joint will cause the wheel wobble feedback. However so will loose steering gear, out of round tire, front end misalignment (caster in particular).
good luck
good luck
First get it balanced. Make sure the tires are in good condition. A bubble in the sidewall will cause that and that tire should be replaced immediately.
If not the tires/balance then check the tierods.
Received 2,329 Likes
If balancing and alignment doesnt seem to do it, you should get your CV joints checked.
rockyboy
08-04-2024 10:35 AM
