Rear Rotors replacement
Very easy procedure. Remove caliper by removing caliper mount bracket bolts, install two, 8x1.25mm bolts into holes top & bottom or disc, and jack the disc away from the bearing hub. A few raps w/ a hammer may help the small bolts jack the disc.
Buy a shop manual of some type to help you. Use jack stands to support car.
good luck
good luck
good luck
good luck
mada51589
Jan 9, 2025 04:40 PM
