Speedometer Problems
Old May 21, 2005 | 12:09 PM
Guys,
I'm having a weird problem with my seedometer. It's jumping all over the place. I may be going 60 then the needle goes to 0, then jump around a little then back to 60 then back to 0. It always works from a dead stop but could start acting crazy at any speed. If I have the cruise on and it starts acting crazy, the cruise shuts off. Odometer continues to work. Any idea's on what to check or where to start. Thanks in advance!
Chris
97' 3.2 TL
Old May 21, 2005 | 12:38 PM
TL-Ridaz96's Avatar
my friend has a similar problem. either the wire is loose or the speedometer is broken.
Old May 21, 2005 | 01:22 PM
TL-Ridaz96's Avatar
here's the link that ebay sells for about $25 bucks in bidding.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33678
it says 2.5 '97 tl. I'm not sure if the gauges will fit for 3.2 tl...I'm sure it fits. can someone justify?
Old May 22, 2005 | 01:40 PM
Thanks for the info
I'm gonna check on that cluster and see if it will work in a '97. Where's the wire that your talking about, behind the instrument cluster or near the transmission? Thanks in advance!
Chris
Old May 23, 2005 | 11:58 PM
2doe's Avatar
it is probably the speed sensor. I believe it is covered under the emissions warranty
Old May 24, 2005 | 03:08 PM
My d4 light started blinking today, I called the dealership and that was the first thing he said it might be, that was before I told him that the speedometer had been acting squirly. I'm taking it in tomorrow. My CEL has been on for a while with code p0401 (EGR insufficient flow) so hopefully they will be able to fix everthing at minimal cost. Thanks for the input!
Old May 25, 2005 | 09:55 AM
$300 for the speed sensor replacement... this sux!
Old May 27, 2005 | 11:03 PM
2doe's Avatar
asked about the emission warranty
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
