relay help
Old Nov 22, 2006 | 08:10 PM
nealzone's Avatar
Red face relay help
does anybody know where the fuel pump relay is on a 97 2.5 tl
Old Nov 26, 2006 | 09:19 AM
TexasHonda's Avatar
The relay is under the dash on driver's side just above and behind the cruise control unit. It looks to be pretty tough to access from beneath the dash. What are your problem symptoms?
good luck
Old Nov 27, 2006 | 06:12 AM
nealzone's Avatar
good luck
thought it was a bad fuel pump {but nooooo}
Old Nov 27, 2006 | 12:06 PM
TexasHonda's Avatar
Main fuel relays have been a problem on many Honda and Acura vehicles since the 90 Accords, and possibly earlier. You would think Honda could have solved this problem w/ a more robust relay, but apparently not.
On Accords, I found that it was much easier to remove the relay mounting bracket w/ relay in place rather than try to separate the relay from the bracket.
It may be possible to access from LH side of dash by removing the trim and front panel pieces. Just a thought in case you can't access from underneath the dash.
good luck
Old Dec 26, 2006 | 10:03 PM
slavik's Avatar
8th Gear
fuel pump relay
my 96 acura tl will not start as good lately now does not start at all people say that is the fuel pump relay It is under dashboard right? how is it look like I have no manual!
Old Dec 26, 2006 | 10:13 PM
KrayzieDxC's Avatar
Khmer Pride
do a search i post a service manual while back. its download able..if not lmk i upload it
Old Dec 26, 2006 | 11:41 PM
slavik's Avatar
8th Gear
please upload thank you so much!
Old Dec 26, 2006 | 11:42 PM
slavik's Avatar
8th Gear
i could not find the fuel pump relay or main relay does someone one how it looks like or what says on it?
Old Dec 26, 2006 | 11:46 PM
slavik's Avatar
8th Gear
I dont know as well I could not find that under dashboard does anyone know how it looks like or what says on it!
Old Dec 26, 2006 | 11:59 PM
slavik's Avatar
8th Gear
i found the servise manual but i could not download anything how do you do that?
Old Dec 27, 2006 | 12:59 AM
KrayzieDxC's Avatar
Khmer Pride
http://fs04n3.sendspace.com/dl/5dd9d...e%20Manual.rar
get winrar to open it from oldversion.com
Jamus22
Jun 11, 2023 10:08 AM
01CLOwner
Oct 9, 2015 01:07 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
Ty-Sama
Sep 21, 2015 05:45 AM
