problem with car starter or ignition
i do not know what is the problem. my car will not start when i turn the key to on. i have to try about 5 times to got the car to start. maybe the starter or the ignition switch it has gone bad. i don t know which one is the problem.
i really want to fix it before it become a major problem. reply to me asap with any information . thanks
If all you get is a single loud click when starter is engaged, the starter solenoid copper contacts are worn out. Some are replaceable, but 2.5TL starter solenoid is not one of them. New, rebuilt, or used starter is necessary. The 3.2TL and 2.5TL starters are difficult to remove.
A search for starter will turn up lot's of guidance.
good luck
good luck
