Power Steering Leak
Power Steering Leak
I had noticed a few drops of power steering fluid now and then underneath the car but in the last few days with the weather warming up, suddenly the car is gushing it. A bottle is literally gone in a day. I know that there isn't too much to the PS system, so does anyone have a diagram of it? I'm guessing that a hose is cracked or the pump seal went bad but haven't had a chance to try and fix it. I got under the car briefly, but its hard to tell where the fluid is coming from as there is a large plastic/metal plate that covers most of the underneath. This is a '98 3.2TL.
Probably blew an o-ring seal at a fitting, or a hose has a leak- with that much fluid I would suspect hose.
Wash everything with citrus type cleaner- engine cleaner and then start the car while friend turns the wheels and you watch for the leak.
I had the same problem.
The return hose became lose at the pump.
A $20.00 hose from the dealer fixed it.
Took me less than 30 min to drain the old fluid , attach new hose and refill.
Originally Posted by The Hawk
Is this a DIY job? Can it be easily accessed from underneath? Much thanks
You need to first make sure the source of the leak.
What I will do is take some picture later tonight and tell you to look for possible source of leaks.
I cannot see fluid from the resevoir side. Its dripping off the center of the cover plate underneath the engine. Pics would be much appreciated. I actually do not have access to the car until tomorrow night, but then on Thurs AM, its going to the dealer, so I'd like to try and get an idea of whats going on, just so they don't try to rip me off. Thanks Again!
Ugggg..... its turns out that the steering rack is pretty rusted and is doing most of the leaking. Needless to say that it'll be big $$$ to get it fixed. Quote was about $1200. =(
thats a bummer but a good lesson for others.
PS fluid does wear out... just like brake fluid- engine oil and everything else.
It needs to be drained and refilled ~flushed~ out of the rack especially!
A general repairs import shop that also does alignments would be a good choice of installers.
yea, thats the part. They mark it up to about $450, labor was about $550, then $100 for alignment and another $100 for misc BS/tax. I'm sourcing a used rack for about $200 and having a friend do it so it should only be about half of the original estimate. thanks for the help guys.
becasue i like to save save save. The part is out of 70K car, and has an 18 month full warranty on it. I have inspected it too, and it looks great. Also, I'm not planning on keeping the car for eternity, so if I get another 60K out of her I'll likely be satisfied.
mike from annapolis
05-07-2017 08:21 PM
