Possible Trans Problem
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Hi everyone
I have 98 2.5 AT with abt 17k miles.
My TL has no power in low speeds up to 30~40 m/h. Also in the cold morning, gear change is very not smooth...I feel the shock very strongly and it doesnt change until very high rpm(over 3000) even if I easily step on the gas.
Do you know how to resolve this???
Any opinons will be appreciated it.
Is D4 light and/or Check Engine light flashing? If yes, get the code (Pnnnn)and post for help. A failed speed sensor can cause hard 1-2 shift, but will set a trans and ECU code.
Make sure trans fluid is clean and full. If over 5yrs/50K a change should be considered.
Mileage is extremely low for a 98 TL. Has it been stored for some time?
good luck
good luck
17K? Are you serious?
Like Texas mentioned, it had to be kept parked for a long period of time.
it was driven an average of 125 miles per month or 1500 miles a year.
SidhuSaaB
05-30-2020 12:40 AM
justin7779
12-25-2015 10:33 PM
