please help figureing out abs codes
Old Jun 23, 2009 | 08:54 PM
lowbird96's Avatar
hi i have a 96 acura 3.2tl and the abs light comes on alot and the tcs comes on once and a wile. i shorted the service check connecter and got
tcs 4 long flashes, and 8 short ones im guessing thats code 48
abs however had no long flashes i got
1 flash pause, 2 flashes, pause, 4 flashes, pause, 8 flases, pause, 4 flashes pause, 8 flashes
id appriciate any help
Old Jun 26, 2009 | 02:49 PM
TexasHonda's Avatar
The pause between codes is 5 secs and between digits of same code only one second.
Code 48 is fault with LR wheel sensor. There are a number of possibilites besides a bad wheel sensor. I would suggest removing wheel and cleaning the sensor and the tone ring (cogged wheel that turns on axle under the sensor). Stuff a rag in the hole and turn the wheel to clean the lugs. Dirt can degrade signal to point where code occurs.
I can send you the pdf pages w/ the symptoms for Code 48 and other codes. PM your email and I'll email the file to you.
good luck
Old Jun 26, 2009 | 07:58 PM
lowbird96's Avatar
i know the abs sound a little off but that is whats its doing. i tryed to take a video of it but my camras not working for some reason.
TypeS860
Jan 10, 2026 11:11 AM
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
