Please Help! EGR low flow and AC problem
Old May 24, 2007 | 10:03 AM
antony75's Avatar
Hi Guys,
I am new member of this forum. My 97 3.2TL has 150,100 miles so I know it is over emssion warranty. My checking engine light is on with a code P0401 EGE low flow. I already replaced EGR valve but the problem still there. I already read many threads how to clean EGR valve but anyone can give me more and further details how to fix a problem...Please help me
Recently, I have AC problem. Turned on AC with warm air blowing, even none of fan runs while AC on. I bought a botle of freon but still warm air. Anyone shows me how to fix please....
Old May 24, 2007 | 03:27 PM
Go90go's Avatar
大日本帝国
It's usually not the valve that's the problem when you get that code, it's the pipe underneath. It's bitch to get to, as deadsetonliving can attest to, haha. Try spraying carb/intake cleaner down the port holes when you remove the EGR, then reset your ECU by disconnecting your negative terminal for 30 seconds or more. As for the AC, we use R134a, not R12, but if the fans aren't coming on, check your fuses first.
~Cheers~
Old May 25, 2007 | 07:45 AM
antony75's Avatar
Thanks for your responding. I will use your guide to clean a pipe of EGR but I read someone recommended drill a hole to remove building carbon, no clue how to do it. Anyone can give me step by step in case the problem still exists even I clean a pipe. As my AC, I used R134a and checked fan relay, fuses but they are good condition
Thanks,
Old May 25, 2007 | 06:06 PM
Go90go's Avatar
大日本帝国
You have to drill if it's caked up so bad, not even chemicals will get rid of it. That's recommended only if the pipe is off the car, though. For your AC, maybe the fan switch wiring is melted or cut, take a look at the wires going into the fan.
~Cheers~
Old May 30, 2007 | 06:37 AM
antony75's Avatar
I already checked all wire and they look good. I saw both fans running when the engine really hot so I think all fan relays or wires are good. My question is if I turn AC on, do both fans have to run? or both fan run only engine really hot?
Old May 30, 2007 | 11:12 AM
01tl4tl's Avatar
One of them is always on with AC- on my 01 thats the passenger side one
Both may run when engine hot
If the AC was empty or close to it- you may just need another can- there is a capacity limit sticker there to advise you
Old May 30, 2007 | 10:16 PM
Go90go's Avatar
大日本帝国
One fan is dedicated to the engine, the other works for both AC and in turn, the engine. It's normal for the fan by the compressor to turn on to help keep it cool. I never paid any attention to them on mine...
~Cheers~
Old Jun 7, 2007 | 09:05 AM
antony75's Avatar
Hi Guy,
I brought my car to independence shop for checking my AC. I have been told Freon was low and then they inserted freon into my car but the AC still not working. Now they said more problem with electric stuff. Fan and compressor work well, so they guess maybe climate control unit goes bad or electric control module, so far I already paid $200 but problem still there, it is pain. Any idea??
Old Jun 7, 2007 | 11:07 AM
pi1996's Avatar
the climate control has a self diagnostic function.
Turn the ignition switch ON (II), then press both the AUTO and OFF buttons at the same time.
let me know which icons are on the climate control display after you do this.
Old Jun 7, 2007 | 12:20 PM
Go90go's Avatar
大日本帝国
^ Yes, plus we don't use Freon (R12) in our systems. Compared to R134a (what we use) the gas is denser, and using R12 can damage the system.
~Cheers~
Old Jun 13, 2007 | 07:33 AM
antony75's Avatar
Icons such as 60 and full displayed as I pressed both AUTO and OFF at same time
Old Jun 13, 2007 | 08:27 AM
antony75's Avatar
Could any one give me 97 TL AC annual troubleshooting? I have 1998 Integra and 2004 TL annual but 1997 TL, I wonder if my 97 TL has same troubleshooting with 98 Integra or 04 TL. Anyone here can show me how to test AC pressure switch and where is location of Climate control unit of 97 3.2TL? Thanks
Old Jun 13, 2007 | 11:31 AM
pi1996's Avatar
that test was for temperature sensors . blower motor, and air-mix motor.. looks like all are fine.
what do you mean by "annual" proubleshooting?
Old Jun 13, 2007 | 12:00 PM
antony75's Avatar
yes, when I pressed both AUTO and OFF, warm air blew out. I have Accord 97, Integra 98, and TL 2004 service manual, there is troubleshooting how to fix a problem. Do you have 97 TL AC circuit diagram? If I have circuit digram, I can figure out the problem
Old Jun 13, 2007 | 12:11 PM
bpjadhav's Avatar
1998 2.5TL
A copy of the self diagnostic result sheet is posted in this thread. The image is not showing up on my machine. You could ask UnsanePyro to repost it.
Old Jun 18, 2007 | 10:21 PM
deadsetonlivin's Avatar
~Cheers~
LOL!!! A bitch aint the word if you go at it yourself definatly wear some nice gloves and take your time.... Should I bring up a picture of the finger!!!
Butttt It has healed well and is back at 100%!
Old Jun 19, 2007 | 12:40 AM
Go90go's Avatar
大日本帝国
^ It's too bad it wasn't the middle finger. That'd been funny if you were driving around giving everyone the finger since you have to keep it elevated, haha!
~Cheers~
Old Jun 19, 2007 | 02:09 AM
Petie's Avatar
1998 3.2TL
Here you go....
http://www.mediafire.com/?539y2vv3jlz
Old Jun 20, 2007 | 09:59 AM
antony75's Avatar
Thanks for all your help. Now I have new problem coming up. This car recently gives me f..cking headache. Radiator fan keeps running until the battery dead, even engine off. I have to take fuse out and fan comes on right away after I connect the fuse. Anyone has idea???
Old Jun 20, 2007 | 10:03 AM
antony75's Avatar
Petie
Do you have AC troubleshooting mannual?
Old Jun 21, 2007 | 02:07 PM
LOL GOGO that was sooo wrong!!!... But that finger is very important to.... Specially when used in combination with the middle finger!!
Old Jun 29, 2007 | 08:15 PM
daredevil0610's Avatar
ACUREVER!!!!
Egr Problem
Can you take a pic of the location of the pipe? I seafoamed mine too and i bought a dtc apparatus too to remove but still after a week it keeps coming back? What should I do?
Old Jun 30, 2007 | 12:13 AM
I'll try to snap a pic tomarrow AM. But in the mean time head over to acura-legend.com and goto thier diy section and search for the egr one. It gives you very good pictures and directions.
Feb 25, 2020 09:57 AM
ExcelerateRep
Sponsored Sales & Group Buys
Jan 6, 2016 09:59 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
Sep 17, 2015 10:16 AM
