P0153 CEL code
Old Jun 30, 2008 | 08:50 PM
Mandy's Avatar
98 3.2 Flamenco Black
Unhappy P0153 CEL code
80K miles on my 98 3.2 and my CEL turmed on this morning.
P0153 O2 Sensor Circuit Slow response (Bank 2 Sensor 1)
Help!
I cleared the code by using an OBDII reader.
I have not used the car yet.
Thanks in advance.
Old Jun 30, 2008 | 10:43 PM
KrayzieDxC's Avatar
Khmer Pride
have you replace your o2 sensor? bank 2 sensor 1 is on your driver side..manifold
Old Jul 1, 2008 | 07:21 PM
Mandy's Avatar
Both sides (O2 sensors) were replaced by Acura about 2.5 years ago, when the car was 60K miles.
Old Jul 3, 2008 | 03:28 PM
Mandy's Avatar
Does this mean I have to replace this O2 sensor again?
Old Jul 3, 2008 | 06:38 PM
TexasHonda's Avatar
It's likely the sensor is faulty or contaminated. I would suggest pulling the sensor connector, checking, and cleaning any oil or dirt. Reset ECU and see if same code appears. If yes, a new sensor is indicated.
good luck
Old Jul 3, 2008 | 08:40 PM
Mandy's Avatar
Thanks, how do you reset ECU?
Old Jul 3, 2008 | 08:41 PM
Mandy's Avatar
Bank 2 Sensor 1 is DRIVER side, right? What do I use to clean sensor?
Old Jul 3, 2008 | 08:48 PM
KrayzieDxC's Avatar
Khmer Pride
ECU is under the carpet of the passenger side, and yes the sensor is on the driver side
Old Jul 4, 2008 | 06:19 AM
TexasHonda's Avatar
You don't pull the sensor. If it's contaminated, it can't be cleaned to my knowledge. Occasionally, dirt and oil will contaminate the connector to the O2 sensor and cause the signal to be degraded. Only disconnect the connector, clean contacts, reconnect, and reset ECU.
ECU is reset by pulling the BackUp fuse in the underhood fuse box for 20 secs, or disconnecting battery negative cable for 20 secs. You will need radio code to restart radio and all radio presets will be lost.
If code comes back, you'll need to replace the O2 sensor at that time.
good luck
Old Jul 6, 2008 | 01:21 PM
Mandy's Avatar
How much is a sensor? Is it the same as the left anf right side? I have cleared ty code through an OBD II code reader, is this not enough? I need to reset the ECU? Thanks.
Old Jul 7, 2008 | 05:44 AM
TexasHonda's Avatar
No, resetting w/ a code reader is fine.
O2 sensors range from $25-$100, depending on whether they are direct replacement (wire harness complete) or universal (cut/splice wires required).
Check ebay and internet for range of prices and products.
good luck
Old Jul 7, 2008 | 06:27 PM
Mandy's Avatar
Thanks...so, I was due for an Air filter change anyway, I replaced the air filter, applied some electrical connection paste (usually used for bulb connections) on the O2 sensor connector.
Cleared the code through the OBDII, took the negative terminal 1 minute.
The CEL has not lit back up, one day of use.
We will see.
Thanks again.
Old Jul 13, 2008 | 07:45 PM
Mandy's Avatar
6 days after no CEL....knock on wood.
Old Jul 15, 2008 | 09:14 PM
Mandy's Avatar
So far so good............knock on wood.....change filters every 15K...helps!
Old Sep 22, 2008 | 09:51 AM
Mandy's Avatar
Well, it came back yesterday, same code. I cleared it using the OBDII. Let's see what happens....
Old Sep 22, 2008 | 09:52 AM
Mandy's Avatar
I will have to check ebay....there was an ebay OEM supplier which sold DENSO O2 sensors...
Old Sep 22, 2008 | 03:13 PM
Mandy's Avatar
Where do you guys get your O2 sensors? I have been checking OEM Denso O2 sensors, they are like $120 from ebay re-sellers. Dealer wants $200+. I see replacement O2 sensors at $50 shipped, non OEM, universal type.
Old Jun 15, 2011 | 11:36 PM
tmnhs81's Avatar
I have same code. It all started after I washed engine bay couple of weeks ago. First time it came ON with half mile drive after I washed the engine. I cleared it right away. Now it came back ON again after 2 weeks or so.. Looks like I have to take the connector off to clean it up..
Old Jun 17, 2011 | 12:45 PM
Mandy's Avatar
Mine has not returned for some time, knock on wood. I usually apply a thin coat of bulb grease on the connector.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
hrothgar02
Sep 28, 2015 11:08 AM
