Overheating Problem
Old Oct 27, 2017 | 07:26 AM
pantera408's Avatar
6th Gear
Overheating Problem
Hey Guys I have a 96 Acura TL 3.2 that I have an overheating problem, I changed the fluid and Thermostat and still overheating, Fan is working. what are the symtoms of a Bad water pump? Is there a way to check it without taking apart? cant see fluid leaking from weep hole.
Sean
Old Oct 31, 2017 | 05:27 PM
tempetom's Avatar
I guess I would run the car until it heated up and look to see if the fluid is recirculating in the radiator.
Old Nov 20, 2017 | 06:35 PM
pantera408's Avatar
6th Gear
Crack on top for radiator cap housing...... Replaced with New radiator and all good !!!
Sean
