Overheating Problem
Hey Guys I have a 96 Acura TL 3.2 that I have an overheating problem, I changed the fluid and Thermostat and still overheating, Fan is working. what are the symtoms of a Bad water pump? Is there a way to check it without taking apart? cant see fluid leaking from weep hole.
Thanks Sean |
I guess I would run the car until it heated up and look to see if the fluid is recirculating in the radiator.
Crack on top for radiator cap housing...... Replaced with New radiator and all good !!!
Thanks Sean |
