Outside Air Temperature Error
Old Jul 10, 2012 | 12:01 PM
Bama Acura's Avatar
5th Gear
2006 TL. Temperature reading for outside is about 6 degrees lower than actual. Replaced Sensor, same thing.
Any ideas?
Old Jul 10, 2012 | 02:10 PM
Go90go's Avatar
大日本帝国
Wrong section, but maybe the dealer can have it recalibrated?
~Cheers~
Old Jul 11, 2012 | 09:36 AM
Bama Acura's Avatar
5th Gear
Outside Air Temperature Sensor
Well, I will answer my own post. It was much easier to find the solution by just Googling Acura Outside Air Temperature Sensor Wrong. Answer:
There is a way with the display on the Acura to calibrate. You just have the display showing the Temperature, then you press the SEL/RESET button for 10 seconds. The display then begins to sequence from O,1,2, 3, on up to -3, -2 etc. When you release the button that amount of temperature has been added or subtracted from the reading. All you need is an accurate read of the outside air temp when you do this.
Old Jul 11, 2012 | 09:40 AM
^good job Bama
Biggie_B
May 27, 2025 05:51 PM
SidhuSaaB
May 30, 2020 12:40 AM
tsx_boy
Dec 13, 2019 08:33 PM
rcs86
Aug 2, 2016 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
