Outside Air Temperature Error
Outside Air Temperature Sensor
Well, I will answer my own post. It was much easier to find the solution by just Googling Acura Outside Air Temperature Sensor Wrong. Answer:
There is a way with the display on the Acura to calibrate. You just have the display showing the Temperature, then you press the SEL/RESET button for 10 seconds. The display then begins to sequence from O,1,2, 3, on up to -3, -2 etc. When you release the button that amount of temperature has been added or subtracted from the reading. All you need is an accurate read of the outside air temp when you do this.
The following 2 users liked this post by Bama Acura:
justnspace (07-11-2012),
Shellyduchsk8s (07-12-2012)
SidhuSaaB
05-30-2020 12:40 AM
Biggie_B
02-26-2017 11:14 AM
rcs86
08-02-2016 06:52 PM
