oil leak??
Old Mar 7, 2006 | 01:01 PM
The_Prophet's Avatar
2.5 T.L 1997
oil leak??
I have a problem my oil leak just under my oil filter(5inch)... do know the problem?
and I have a 97 2.5 T.L
thank
Old Mar 14, 2006 | 12:17 PM
TexasHonda's Avatar
If you're sure the oil leak is coming from the oil filter there are three possibilities; the oil filter body, oil filter seal, or the oil filter mount/engine seal (usually an oring) is leaking. Most mounts have two bolts holding the mount to the engine block. Not unheard of for either filter or mount bracket to leak.
good luck
Old Mar 14, 2006 | 05:11 PM
2.5 T.L 1997
thanks
I find the problem! it's the pressure switch... I was tough to find the problem..but its good.. only 20$ for the switch
Old Apr 20, 2006 | 10:41 PM
nick96acuratl's Avatar
i had a similar problem but it was the seal behind the oil filter bracket.. 8 bucks and fixed my problem.. was leaking for a year because it was mis diagnosed by a mechanic that said it was my O ring seal where the shaft goes through.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Avenger411
Oct 11, 2015 03:53 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
