oh shit!
Old Dec 28, 2008 | 08:37 PM
apz24's Avatar
oh shit!
i dont know whats wrong with my car but ill start the car and it put it in drive and hit the gas but its like sluggish and then 2 seconds later it will zoom 2 the next gear and be find i do have a oil leak but it good on oil please can someone have a idea wat could be wrong?
Old Dec 28, 2008 | 09:02 PM
vas25tl's Avatar
The Box
Could be a lot of different things....could be clogged fuel injectors, engine not getting enough fuel until higher RPM's? how does it run when it'd just idling?
Old Dec 28, 2008 | 09:03 PM
Aman's Avatar
Your Friendly Canadian
you know, learning how to spell would be a great start.
Old Dec 28, 2008 | 09:19 PM
vas25tl's Avatar
The Box
How does that help with the problem he's having?
Thank you for your input.
Old Dec 28, 2008 | 09:22 PM
Aman's Avatar
more people would help.
My accord is sluggish on throttle tip-in nothing really you can do about it.
Maybe it's idling too low?
Old Dec 28, 2008 | 09:26 PM
01tl4tl's Avatar
where is the oil leak coming from- the rear main seal? get that fixed
Do you mean: when you start the car and put it in Drive, it takes a few seconds to engage and go forward?- then when it shifts to the next gear it makes the engine rev up -zoom- before the next gear engages and makes the car go forward?
Old Dec 28, 2008 | 10:30 PM
TLin401's Avatar
'13 Hyundai Sonata
I had a problem like this recently but my oil was disappearing and then I found out that it was my oil filter. I'm trying to understand you as well. Like does the car kick when you press on the gas or does it go like slow and then it revs then goes back to normal? I think it could be your transmission if it is kicking or you might just need to change a fluid (ie. transmission or oil). It could also be what vas25tl stated as the fuel injector or what 01tl4tl states as a rear seal. try to give us as many details as you can because to much information is never bad so that we can help you narrow down the problem to what it might be.
Old Dec 29, 2008 | 08:00 AM
levelfamily's Avatar
levelfamily Ent.
yo my friend if you going to write something like this, don't post anything, this way you don't help anybody... if you don't like the way a wrote in English, ma bad mister teacher, not everybody has the lucky you had to go a rich school, some people in this forum are spanish like me, and we're not really good writing in English. opss.
Old Dec 29, 2008 | 10:43 AM
01tl4tl's Avatar
conveying the essense of the problem is whats important, not your spelling or typing skills
Just get out as many facts on the problem so we can help~
Old Dec 29, 2008 | 04:10 PM
Mr_Outside's Avatar
My girlfriends car did the same thing and the mechanic said he just cleaned the tranny and it fixed it.
Old Dec 31, 2008 | 12:33 AM
apz24's Avatar
w/e dork i could care less about spelling
Old Dec 31, 2008 | 12:42 AM
apz24's Avatar
I know that its not the transmission. sometimes the idling is really low and if i don't get it d4 fast enough to pull of it shuts off but this is only sometimes so i have no idea. im lost
Old Dec 31, 2008 | 12:48 AM
TLin401's Avatar
'13 Hyundai Sonata
Have you ever tried seafoaming? Seafoam helps the car's idle by getting rid of carbon build up in the engine over the years and miles.
Old Dec 31, 2008 | 12:54 AM
apz24's Avatar
ya i did it like 5 weeks ago but i didn't put any in my gas tank should i try it again and put some in the tank?
Old Dec 31, 2008 | 01:02 AM
TLin401's Avatar
'13 Hyundai Sonata
I would do that. Have you changed your tranny fluid at all? I would do a drain and fill if you haven't done that and maybe even change the screen. You can also change the differential fluid and that might help. There are DIY for these is the Problem & Fix section.
Old Jan 15, 2009 | 12:02 PM
apz24's Avatar
it was egr valve that was bad and causing the weird accelration but its coverd under warenty so its free! but i did have to pay to fix my oil leak but it was only like 200 bucks, but i have to pay for labor even tho the egr is under warrenty?
Old Jan 15, 2009 | 01:10 PM
andrew070489's Avatar
glad to hear you figured it out..
Old Jan 15, 2009 | 05:09 PM
main70072's Avatar
No you shouldn't have to pay for labor if it's under warrany. I had mine replaced last month under warranty and didn't have to pay a penny. Just curious, was your CEL on?
Old Jan 16, 2009 | 10:36 AM
apz24's Avatar
nice and ya it was if i had 75000 miles i could get some free stuff but i onlyy have 73xxx kinda sucks
Old Jan 16, 2009 | 04:57 PM
noRe456's Avatar
Speak for yourself buddy. I have a lot of HISPANIC friends that know how to read, write, and speak english properly. It's not about being lucky, rich, and going to a rich school. It's about actually paying attention while in school. Good luck.
Nickb257
ILX Tires, Wheels & Suspension
Oct 27, 2015 10:13 PM
