noise on the right front tire
Old Mar 15, 2010 | 02:40 AM
gunitandresb's Avatar
5th Gear
Exclamation noise on the right front tire
there is a noise in my right front tire and i dont know
what it can be .it goes away and it comes back at random times the brakes look ok but i havent take the tire out and give it a good check. and another thing is my car loses speed righ away after i let the gas pedal go. anyone know what it could be?
Old Mar 15, 2010 | 11:16 AM
main70072's Avatar
Your car loses speed right away after letting go the gas pedal tells me that your brakes are dragging. You might want to check the calipers out ASAP. What model car do you have?
Old Mar 15, 2010 | 12:19 PM
simm's Avatar
98 Blue 2.5 TL 200,050 mi
Huh, I have the same problem with my car. But mine acts like it's not downshifting properly because it jerks to shift down to 2nd or 1st gear.
Old Mar 15, 2010 | 01:59 PM
5th Gear
i have a 2.5 tl 1996
yeah i think mine is doing the same thing. i guess im gonna just go get my car check to see if there is any serious problem
Old Mar 15, 2010 | 02:28 PM
TLin401's Avatar
'13 Hyundai Sonata
Drive the car for about 20 minutes and then see if the rotors get hotter than normal. If they are, then that is a sign of seized calipers.
Old Mar 15, 2010 | 02:41 PM
akash4u's Avatar
Does it happen at a particular speed?
Old Apr 5, 2010 | 04:44 PM
5th Gear
well the sound stop for a while so i didnt got it check . but now is back an louder . an yeah the rotor is way hot when im done driving even smells like metal burn. an it happens at any speed when im goin 5mph or 60 i can still hear it .
Old Apr 5, 2010 | 05:13 PM
Mandy's Avatar
98 3.2 Flamenco Black
Shoot your calipers are sticking, you have seized slider pins! Go get them checked out now!
Old Apr 7, 2010 | 11:34 AM
5th Gear
yeah but i get paid next thursday . u think ill be ok driving it like this for 7more days? oh an is the rear break not the front.
Old Apr 7, 2010 | 12:26 PM
myisanog's Avatar
i would find another car to work in . rear brakes are much more of a hassle to mess around with and i bet they will charge more for labor
Old Apr 8, 2010 | 12:03 AM
5th Gear
yeah i just wanna get the parts an do it my self
Old Apr 8, 2010 | 10:49 AM
bigwerm187's Avatar
Str8 Home built
if its not your brakes and you fix that and u still have the same problem its going to be your wheel bearing.. Yeah i had the same problem what i did was i lifted my front end and took of both tires. then i put in drive with out the tires and i started to listen were the noise was comeing from and yeah it wasnt the caliper it was the bearing. BTW i replaced it ASAP..
Feb 25, 2020 09:57 AM
08 NBP TL
Sep 8, 2015 08:49 PM
devinv1994
Sep 8, 2015 01:29 PM
aces2412
3G MDX (2014-2020)
Sep 7, 2015 08:40 PM
nuldabz
Sep 3, 2015 05:49 PM
