New to forum. New some help with a CEL
Greetings,
I am new to the forum, however I have been a long time Honda/Acura owner. I have owned two Honda civics, one Honda Delsol, a 98 Acura ITR, and now a TL. I currently own a 98 2.5TL and today for the first time the check engine light came on. The car has 105K and is up to date on all the maintenance. I don't own a HELMS for the TL (stupid I know), and I would really appreciate if someone could help on the process to pull the CEL codes.
How do I go about checking for the CEL codes? Thanks in advance for any help!
Originally Posted by waynegro
Greetings,
go to ur local autozone - show them the socket and they will pull the code for free.
Codes can also be self-extracted by shorting the service check connector (blue 2 wire connector) under the glove box. Turn key ON and CEL will flash the codes. Long flashes for 10s-digit, short pause, and short flashes for units digit. Multiple codes are separated by a long (5-sec) pause.
A shop manual is your best investment to prevent inadvertent damage when you're performing a DIY repair. Helm manual is best by far, w/ a Haynes the next best, IMO.
good luck
good luck
*Update*
Turns out CEL is for a problem with the 02 sensor (thank goodness). Should be a quick and inexpensive fix.
You guys think it would be covered by the emissions warranty? What is the best way going about getting Acura to stepup and cover this?
*Update*
Or, quite honestly, call your local dealer, and they should be able to help.
*Update*
Hope everything works out - let us know how it goes.
