Need your help! Rack and Pinion slack?
Old Mar 18, 2011 | 07:39 PM
DUECEON9ER's Avatar
Thumbs down Need your help! Rack and Pinion slack?
So for the past two years I"ve replaced steering components like crazy so I have all the ideas for any faults I may have. My latest, because of seals being destroyed on rack, I have replaced my rack with a rebuilt one and everything seems to be going fine minus alot of slack I cannot seem to tighten. I"ve gotten an alignment, new inner and outer tie rods, replaced all the mounting bushings, checked all possibilities, next is either the steering linkage or the nut for the adjustment underneath the gearbox. My question is has anyone in this forum ever done this job? And what would the proper procedure be? Any help will be appreciated C'mon guys I really need your help on this one I just want the steering to be stiffer my friend drove it and also said it's "too" smooth. I don"t want it to be a complete waste of like $400.
Old Mar 18, 2011 | 09:04 PM
main70072's Avatar
Not sure of what you meant by stiff and smooth, but if you are referring to the amount of force it takes to turn the steering wheel then I would have to say that our cars have very lite steering. Everyone who has ever driven my car were all surprised and commented on how easy it was to turn the wheel.
Old Mar 29, 2011 | 08:21 PM
DUECEON9ER's Avatar
Okay so I found where the slack is just have no idea how to tighten it up any ideas would be helpful. Behind the steering wheel down aways is the steering joint the connects the rack to that rod up to the steering wheel. So there is definitely movement is that area just don't know how everything seems really tight? I'm in the blue again....
http://www.acuraautomotiveparts.org/...s=&view=normal
added the pictures so you can get the idea
dirleton
20
Oct 16, 2015 01:48 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Froid
Sep 27, 2015 06:16 PM
miguelalanis
Sep 21, 2015 01:04 PM
CaliBud916
Sep 19, 2015 01:56 PM
