need help with heat
Old Apr 4, 2012 | 09:17 AM
Nimir85's Avatar
7th Gear
need help with heat
i have a 98 2.5 and the heat only works while im driving, also if im stuck in traffic for too long the car will over heat unless i have the heat on. ive been told it may be the water pump, and the heater core could be clogged. a little bit more input would be very helpful as i dont want to spend money and time replacing good parts.
Old Apr 4, 2012 | 02:04 PM
hondafreak513's Avatar
Try making sure all air is bled out of the system, a air pocket in the coolant will cause this..
Old Apr 5, 2012 | 06:33 AM
Nimir85's Avatar
7th Gear
whats the best way to bleed the air?
Old Apr 7, 2012 | 06:44 AM
Nimir85's Avatar
7th Gear
how can i bleed the air out of the coolant system?
Old Apr 11, 2012 | 02:19 PM
icecoldone1906's Avatar
I think it is possibly the temp sensor on top of the water pipe right next to the upper radiator hose. Also you might want to change the water pump and themostat...neither cost that much when you talking blowing a motor if one goes out.
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
TL14
Sep 24, 2015 04:37 PM
