need help
Old Aug 8, 2012 | 11:08 AM
4x4_mafia_jon's Avatar
need help
i will provide beer and pizza!
i have a starter issue with my acura.. its a 1996 3.2.
i can turn a wrench but just would like someone who knows this car better then me to look over.. i will be trying to fix it at my house this weekend if anyone would like to come over..
why is my name 4x4... well i have a bronco that takes most of my money if the wife doesnt get it first.. need some help
thanks, im located in the la area in hacienda hieghts ca
Old Aug 8, 2012 | 11:45 AM
tempetom's Avatar
Good luck, John.
I went through this several years back and it ain't easy. Check out the starter sticky and you will get some ideas. It would be great to have access to a lift. I was getting woozy and disoriented when I did mine. I made it more difficult by almost cutting off my right forefinger the first day I worked on mine. I was hardheaded and didn't get it sewn up. It's ugly, but it still works as does my starter. If you lived near here, I'd share a beer and "supervise".
Old Aug 8, 2012 | 01:12 PM
yea i think ill get on it whats the worse that can happen?
any pics you can find of the started or where is the best way to access it would be a great help.
Old Aug 8, 2012 | 02:41 PM
so took it in yesterday and they just called me
320 for the starter.. is that a good price?
Old Aug 8, 2012 | 03:04 PM
tempetom's Avatar
Doggoneit Jon, I had or have a pretty complete step-by-step for doing the starter, but can't find it off hand. You will have to jack the car up and block it safely, remove the driver side wheel, drain the differential, disconnect the ball joint and remove some parts, remove the driver side driveshaft after unstaking the hub nut. This is too misleading. I'll really try to get the step-by-step info asap. I didn't need to remove the exhaust like it says in some manuals, but I did remove the heat shield on it.
Old Aug 8, 2012 | 03:29 PM
tempetom's Avatar
Here are several pdfs to get you started.
As I may have mentioned in the starter sticky posts, if I had it to do over, I'd change both the starter mounting bolts to socket head cap acrews. They would be special order from a good hardware supply house, but would make the reassembly lots easier. It ain't fun trying to hold the hex socket on a bolt head with 15 extensions and universal joints on a socket wrench.
File Type: pdf
File Type: pdf
