Need Headlight Wiring Diagram for HID kit install
I'm looking for a headlight wiring diagram for my 1998 acura tl 3.2. I need to know which is high beam and which is low beam. I bought a low beam only HID kit for it and it only comes with only two wires. When plugged in and turned on the dumb thing only works on HIGH beam. I have moved and switched every possible way and still only works on high beam. Do I need a relay or did I blow a fuse?!?! ALL help welcomed...lol Thanks!
Here is a good online parts catalog that may help others in the future.
http://www.acuraautomotiveparts.org/...p/mws/home.jsp
i had this same problem today. which ones did you use for your high and low? after messing with the wires i destroyed my bulbs
i hope my ballast arent bad either. looking at the plug and play harness and black on top, does the hib bulb go on the left and the high go on the right? thats assuming im looking at the plug with the metal prongs pointed towards me.
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
11-13-2018 04:44 PM
nuldabz
09-03-2015 05:49 PM
