need advice on 96 2.5TL
Old Feb 14, 2011 | 10:47 AM
matt2.5's Avatar
Check engine light on. Parts store shows code 1382-Crankshaft positioning sensor. Anyone ever replaced this sensor? Is this a difficult job? Should this be done by A mechanic?
Old Feb 15, 2011 | 06:56 PM
TexasHonda's Avatar
If you have a Volt-Ohm Meter (VOM) you can check the resistance of the sensor on the L shock tower (6 pin connector). Check the Orn and Yel/Grn wires to the sensor. Resistance should be 0.5-1.0 kohms. If sensor checks good look for a wiring or connector fault. If it checks bad the sensor will need to be replaced.
Bad news is this requires removal of timing belt. This is a fairly demanding job and requires advanced DiY skills.
If resistance at shock tower checks good, you should check resistance at the ECU connector under the dash. If these also check good, the ECU may be damaged. I had to replace ECU on my 2.5TL due to a circuit board fault.
good luck
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
lilian_rz
Integra
Oct 18, 2015 01:17 AM
