My electrical system is possessed!!
Old 03-04-2007, 07:15 PM
8th Gear
thku4grace's Avatar
I have an 1996 Acura TL 3.2. I have electrical system problem. When I first start my car in the morning it usually starts up normally. However, after I have run the car for 30 minutes or so if I stop and restart my car, I often have problems. It doesn't start slowly like a run down battery might do but instead I get nothing. No turnover at all. I can try it numerous times without the car engaging at all. But if I wait for the car to cool down from normal operating temperature, after 30 minutes or so, it will start up without any problem. Once again, its not a slow start, its no engagement or a normal start.
I have already checked the battery and its fine and I've replaced the starter with only a small change in vehicle behavior. Strangely enough, a few months ago my car would experience this same type of starter problem but only when it had sat overnight. No slow start, just nothing. But once I would get it started I could stop and restart my car as often as I wanted all day without any problem. I'm perplexed. Would love to hear from someone who understands this problem.
Old 03-04-2007, 10:10 PM
大日本帝国
Go90go's Avatar
Have you checked the keyswitch? That stupid $55 part locked my solenoid into starting for 10 minutes, forcing me to replace the whole starter...
~Cheers~
Old 03-08-2007, 12:03 PM
8th Gear
thku4grace's Avatar
Thanks for the response. However, all the dashboard lights come on like they are supposed to. Doesn't that mean that the keyswitch is OK? Frankly, I'm afraid that I got a bad starter but want to pursue other angles that are less costly and make sense first.
SinCityTLX
20
10-19-2015 11:23 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
joflewbyu2
10-08-2015 11:16 AM
Cgannotti
09-25-2015 05:04 PM
maharajamd
Console & Computer Gaming
09-24-2015 03:31 PM
Quick Reply: My electrical system is possessed!!
