knocking clanging under excelleration, while moving
Old Apr 14, 2011 | 02:36 PM
kigidy's Avatar
4th Gear
1998 2.5 tl recently noticed a knocking or clanging while excellerating only when excellerating lightly. if i push a little harder it goes away, it doesnt do it while in park, or while in drive sitting still, i can not reproduce this sound in my garage, the engine sound great and seems to be running fine but wheni drive down the road i get the issue. it seems to be more common when going around 25 mph, slowing down a little and then speeding back up with light excelleration.
please let me know if you guys have any idea.
Old Apr 16, 2011 | 08:28 AM
TexasHonda's Avatar
CV axles are a possibility. Notice whether you get any popping/crunching sounds when turning sharply at slow speeds.
Also check exhaust system shields carefully. They can cause rattling/clanging sound under acceleration.
good luck
Old Apr 26, 2011 | 09:35 PM
kigidy's Avatar
4th Gear
does it going straight or turning, i was thinking maybe it could be tourque converter or something to do wi.h the flex plate. does that make any sense with what i said the symptoms are?
Old Apr 26, 2011 | 09:39 PM
kigidy's Avatar
4th Gear
does sound similar to an exhaust shield rattle but dont think thats the issue. ive fixed a few exhaust rattles already, before this issue. cant find anything loose underneath. also thought i would add that it has about 115,000 on it.
Old Jul 5, 2011 | 09:25 PM
Jasonlives2's Avatar
Have you overheated the engine lately? Does it sound like a metal ball banging around in a paint can? If so it could be detonation, a broken valve spring, or bad water pump echoing through the coolant channel in the engine., and if you' re real lucky it might only be a bad tensioner.
SidhuSaaB
May 30, 2020 12:40 AM
ITSJESTER
17
Dec 6, 2018 02:29 AM
07Acuradude
Sep 29, 2015 03:01 PM
mars
Sep 28, 2015 11:03 AM
STL TL-S
Sep 23, 2015 08:52 PM
