How to replace the D4 light
Well, for everyone out there who wants to replace that pesky little D4 light, heres how to do it. I did it today, and because no one has wrote up a nice detailed thing of instructions, I figure that I will take it upon myself. First one I have ever done.
What you will need:
Short philips head screwdriver
Long philips head screwdriver
Small flathead screwdriver (or similar)
D4 light
This only took me about 30 minutes to do from start to finish, it really isnt that bad if you have some background on what you are doing, and even just a small amount of skill with a screwdriver.
Also, the screws are all different, so try and keep them seperated so that they all go back into the right spot and you don't run into any problems.
Alright, first you need the light from your dealership, its part number 37103-ST7-003 and should cost you less then $5.
Now, you need to pull off the trim around the instrument cluster, its the piece with the 3 vents and the clock, and also the black trim around the instrument cluster closest to the wheel. Start by taking out the two screws above the instrument cluster, you'll need a short screwdriver so that it can fit in there, tilt the steering wheel down for the most room that you can get.
There is a spot, which I believe should hold two more screws, but my particular car did not have any there, maybe from a dealership not putting them back in or something, but they are behind the flap that is above the steering wheel.
Now you have to start pulling the trim out. When I did it I grabbed the black part and pulled out towards me, the top and bottom at the same time, and this got the left half of it out pretty easily.
For part of it, you may have to use a small flat object to wedge under the trim and peel it out. I used a small flat head screwdriver, with a smooth end, not ridged, because it would probably scratch things up. Be careful doing this, you don't want to bend anything too much and end up breaking something, if you need help, ask for it, its something anyone can help with.
Next, you have to unhook the wiring going to the clock and the hazard light switch so that you can pull everything out of the car. I believe one of them pulled right off, and the other just had a little snap that I unsnapped with the screwdriver.
Now, you should be able to take the entire piece out of your car and take a nice picture of it like so:
At this point if you really want, you can dust out the vents for the heat and everything, mine were a bit dirty but nothing that bothers me, and I dont notice it while driving.
Now there are some more screws to take out so that you can access the back of the instrument cluster. There are two on the side, and two on the top, though one was missing in my car (I see a bad trend here...
). The first two are on the top, the black tabs are where they are, the two other screw holes are for the first two that you removed. I almost dropped the screw, and I can imagine it would have been easy to get if I did (just remove the kick guard), just a pain and more time spent, that could have been avoided.
The next two are on the sides, they are above a small stud that makes sure the cluster is lined up right and everything will fit back together. One on the left, one on the right.
At this point, you should be able to remove the instrument cluster, pull it straight out towards you, and then spin it downwards. You don't have to disconnect the wiring or completely remove it to put the light in, you can just sort of rotate it down and pull the left side out a bit to get access to the light.
The staggered row of lights near the center is what you are aiming for. The D4 light is the fourth one up from the bottom (1,2,D3,D4,N,R,P respectively). The light twists about a quarter turn, then pulls straight out. Just drop yours in and twist it so it is lined up like the other ones, you can see where the wiring of the light has to touch the back of the cluster.
Now that its in, put up your parking brake, put your key in, put it in the II position. This way the gear selector lights light up. Step on the brake and shift down to D4, your light should light up, if it does, your done, and can reassemble everything in reverse order. If it doesn't work, either I wrote this wrong, or you did it wrong, or there is another problem.
What you will need:
D4 light
Originally Posted by SurfingScotty
Your a stud, Ken-dogg! The pictures are a huge bonus! Thanks for the help!
The thanks should go to UsanePyro!
Give him some reputation points
I changed the bulb today!! Instead of paying $5 for a bulb, I swapped it with the gear 1 indicator bulb. I didn't feel like paying for it, especially when I rarely put the shifter down there anyway. Thanks!!!!
Originally Posted by YNOTxTONY
Funny thing...
My D4 light went out 3 years ago, but last month it started working by itself.
Weird
Weird
yea same here like i remember for the longest time the D4 light didnt work.. then all of a sudden like around the end of december/beginning of january it started working again
I replaced my D4 light this weekend, and have to say it was embarrassingly easy. It took about 30 minutes, and that included my getting all anal about cleaning around the instrument cluster and panel trim. There are only six screws total, but if you have a magnetized screwdriver to keep hold of them it might be helpful.
Also, I ordered the necessary part online from DelRay Acura: http://www.acuraoemparts.com/delray/jsp/home.jsp. Just put in your VIN number, and the site gives you a complete rundown of all parts for your vehicle. Cool.
Originally Posted by UnsanePyro
Yeah, I was hoping that if I wrote it out well, it would get a sticky, it seems like its been brought upa few times, but never answered as completely as this.
I used this DIY to replace my D4 light. I've never worked on my car before and rate my skills for these type of jobs at -3 on a scale of 10.
It was breeze - great write up UnsanePyro! Thanks a ton!
Nice I did the exact thing last weekend when I put in my glow gauges.
Originally Posted by daemonicus
it was kind of unnecessary to quote that entire DIY but so be it. which light are you talking about replacing? there's about 25 of them on the entire cluster.
mod edit: quote removed
by the way just got a TL and im loving this site!
98 TL 2.5
Thanks much Unsane, I'll swing by the Honda dealer after work to pick up the little bulb. This should add about 15 horsepower, or at least be one less thing to annoy me.
PLEASE STICKY THIS THREAD!
