How do I replace studs?
Old May 15, 2008 | 09:44 AM
DiegosAnotherR1's Avatar
How hard is it to replace studs from the front end of 2.5TL? Is it as easy as taking off the caliper, then banging the stud in untill it comes out the other side?(I read some where a honda owner did this w/ a hub over rotor design) or will I have to pull out the hub?
Old May 16, 2008 | 06:15 PM
LDH's Avatar
LDH
I
Yeah, it should be the same for ROH and HOR. Just spin the stud to where the caliper is, and hit it out with a hammer. Where the stud is positioned the rotor should be completely open.
Old May 17, 2008 | 12:43 PM
Go90go's Avatar
大日本帝国
Let's hope yours didn't seize like mine did, . I ended up grinding the hub and taking them out from behind.
~Cheers~
Old Jun 5, 2008 | 06:30 PM
Thanks guys. I just wanted to put longer studs for 15mm spacers
cycdaniel
Dec 17, 2019 10:58 AM
obert
Nov 14, 2015 09:59 PM
DUECE_DXJ
Sep 24, 2015 04:54 PM
jmoney2001
Sep 11, 2015 12:07 PM
mtl_ilx
Sep 3, 2015 09:48 AM
