Help verifying ABS codes w/YouTube video
Old Aug 6, 2008 | 01:56 PM
BronxAcuraTL's Avatar
i'm getting 78 and 87 87, what do the pros say? TIA
http://www.youtube.com/watch?v=U7_51JYFvw0
Old Aug 6, 2008 | 03:40 PM
KrayzieDxC's Avatar
Khmer Pride
as for reading your codes this what i got
1-7 Wheel Sensor
1-8 Wheel Sensor
8-1 Cpu
2-6 no idea..no info on that
anyone else care to check and makesure.
Old Aug 6, 2008 | 03:55 PM
omg you're reading 4 different codes?? im gonna cry!
Old Aug 6, 2008 | 04:23 PM
KrayzieDxC's Avatar
Khmer Pride
i don't know, how many the codes suppose to spit out.. i think its 3 , i dont know where you got 78 and 87 87, suppose to read long and short blinks
Old Aug 6, 2008 | 05:01 PM
TexasHonda said in another thread that one start pause is for "system" ready-then as he put it: ffff p f = 41, so thats how i counted the pauses + flashes. Not sure yet..
Old Aug 6, 2008 | 07:20 PM
TexasHonda's Avatar
Earlier models 95-96 used the all short flashes code. I probably read wrong section of manual in my earlier post on the ABS lights. I only recently discovered there were two ABS sections in my manual. So far I haven't had any ABS problems w/ my 97 2.5TL.
This code is same as my 97 2.5TL. What vehicle?
I interpreted three codes; 1-7, 1-8, and 8-1.
1-7 and 1-8 are LR wheel sensor faults. Check sensor for connector damage, wire damage, grease on the rotor lugs underneath the sensor, and/or grease on the sensor. Check sensor resistance to be w/i 550-850 ohms.
8-1 is CPU. This could be a false code. I would see if you can find any faults w/ rear wheel sensor, reset ABS controller and see if code returns. If code returns a new ABS controller is needed.
good luck
Old Aug 6, 2008 | 08:05 PM
i have a 3.2; can i remove the wheel and have good access to sensor or is a mechanic called for?
is this:
6 57110-SW5-J11 MODULATOR ASSY. 1 1998 TL 1112.07 856.29
(http://www.acuraautomotiveparts.org/acura/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=TL&catcgry2=1 998&catcgry3=4DR+BAS3.2&catcgry4=KA4AT&catcgry5=AB S+MODULATOR+(+97-98)&ListAll=All&vinsrch=no&systemcomp=&vinnoT=&tri m=&trans=&view=normal)
..what you call the "ABS controller"? could it also be responsible for my seperate issue of hearing a click every time the gas pedal is pressed?
I found the Left rear ABS sensor, no.41 and i dont think i can find a better price w/out having to cut wires; a possible DIY?:
http://www.acuraautomotiveparts.org/...s=&view=normal
Old Aug 7, 2008 | 03:28 PM
KrayzieDxC's Avatar
Khmer Pride
the sensor is near the bearing.
try to find a used abs cpu. or reset your abs light
Old Aug 7, 2008 | 06:54 PM
TexasHonda's Avatar
Used ABS Controller
No, the parts you located are the ABS modulator assy. ABS Contoller is under the dashboard. Car-part.com will locate a used ABS controller near you.
Yes, the clicking is likely a power relay in the ABS system.
Replacing the wheel sensor is dead simple. Pull a few bolts and disconnect electrical connector. Plug in new and bolt in place. Did you check resistance of sensor.
good luck
Old Aug 8, 2008 | 02:14 AM
I'll have to borrow a friends multimeter, how many ohms is a good sensor?
why are thier two codes for one wheel sensor?
Old Aug 8, 2008 | 07:13 AM
TexasHonda's Avatar
Ohms spec is in my original post. Once code is for sensor fault (short/open) and other is for noisy signal.
good luck
Jamus22
Jun 11, 2023 10:08 AM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
