heater problems
Old 03-17-2006, 03:37 PM
cdraper's Avatar
Unhappy heater problems
My 96 3.2 heater is not putting out heat. Any suggestions??? Thanks
Old 03-17-2006, 05:07 PM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
how does the engine temp look??? is it in the middle??? i would check the lines coming from the engine into your heater core...
Old 03-17-2006, 09:48 PM
cdraper's Avatar
heater
My temp will remain stable than all of a sudden peak....It will than drop back down to normal (mid range) and remain stable. I checked the oil for coolant and everything looks fine. I had just taken it to the dealer and they changed the coolant. Any suggestions?? thanks
Old 03-17-2006, 09:49 PM
cdraper's Avatar
Is it a thermastat?? or something more costly???
Old 03-17-2006, 11:01 PM
KaMLuNg's Avatar
if your temp is sporadic like that that is a sign for BHG... that is good that the oil does not have a sign of coolant... check the exhaust, does it look white with a sweet burning smell???
if i were you, i would go get a leak down test... that will tell you for sure if it is a BHG, but from the sound of it, no heat and sporadic temp.. u may be headed in that direction.. it is common with our engines...
http://www.acura-legend.com/vbulleti...ad.php?t=65753
Old 03-27-2006, 12:10 PM
4th Gear
stappa's Avatar
I have a 98 3.2 and have a similar problem.
I only lose heat when the car is sitting still. The heat works fine when the car is moving but if I'm stopped at a drive through window for a minute or so the heat will slowly stop coming and I'll just get cold air.
Old 03-27-2006, 03:03 PM
1998 2.5TL
bpjadhav's Avatar
I have a 98 2.5TL and I have the same problem as stappa. If the car is sitting still, I get no heat - like waiting at a red light, etc. As soon as I start moving, the heat returns gradually.
Old 03-29-2006, 06:32 PM
cdraper's Avatar
heater problem
Here's what happened. I thought the worst..head gasket or heater core or water pump but when I took it to the dealer it was a small pinhole in the upper radiator hose. I was loosing antifreeze at 20 PSI. This slow loss of coolant caused my heater to not blow heat. I replaced the hose and SNAP! it was fixed. I hope this helps..
Old 04-04-2006, 05:50 PM
kickers's Avatar
try to check your heater core, it migt be worn out and needs some replacement, also check your radiator for some leaks.
SidhuSaaB
05-30-2020 12:40 AM
Biggie_B
02-26-2017 11:14 AM
07Acuradude
09-29-2015 03:01 PM
Quick Reply: heater problems
